Old 07-27-2019, 03:30 PM   #1
Emmit51
Emmit51's Avatar
Default Water pump removal help
Hi folks.
I’m trying to get the water pumps out of my 51 custom fordor 8BA. Managed to get all four bolts out for both, surprisingly. Problem is the crankcase vent tube on the drivers side. It’s blocking the top inner bolt so i cant remove it. Any tricks to this? I loosened a nearby clamp on the vent tube, but the tube doesnt want to move. Read thru a few threads on water pump removal, but didnt see anyone saying the vent tube needs to come out. Appreciate any pointers. Thanks. Emmit
Emmit51 is offline   Reply With Quote
Old 07-27-2019, 03:36 PM   #2
alanwoodieman
Default Re: Water pump removal help
you will need to remove the vent tube, it is just sort of "pressed" into the manifold and if you remove the clamp bolt and wiggle it around it will pull out
Old 07-27-2019, 03:51 PM   #3
Emmit51
Emmit51's Avatar
Thanks. Will give it a shot
Old 07-27-2019, 04:52 PM   #4
51504bat
51504bat's Avatar
The road draft tube is a 2 piece unit. If the lower section is still there is has a bolt down as well that might be hanging this up.
Old 07-27-2019, 07:16 PM   #5
Emmit51
Emmit51's Avatar
Default Re: Water pump removal help-part 2
Well, after a bit of a wrestle, i did manage to get the tube out.
Now, another problem. I thought i had broken free all the bolts, but when trying to take out the pass water pump, i realized the one in the hose connection wasnt really moving. A photo showed it is corroded to the point where my socket just spins on it. I tried different sockets metric and SAE but nothing doing.
So, i understand the best way to handle this is to weld a nut onto the bolt - but i dont have a welder. Anybody got any ideas?? Car is in Santa Barbara area (Ca) in case someone is close by with a welder and can help. I’ll make it worth your while
Thanks
File Type: jpeg 01A243C5-1C71-429F-8FD7-7FDA38ED246C.jpeg (130.9 KB, 56 views)
Old 07-27-2019, 07:18 PM   #6
JSeery
JSeery's Avatar
There is an extractor socket that cuts into the head.
Old 07-27-2019, 07:46 PM   #7
Emmit51
Emmit51's Avatar
Dang, that’s cool. Thanks!
Obviously, i need more tools !
Old 07-27-2019, 09:53 PM   #8
51504bat
51504bat's Avatar
Not sure you can get in there to weld a nut onto the bolt and the prior owner may have used a stainless bolt. That said if all else fails you may have to destroy the pump to get to the bolt. Hopefully not.
Old 07-28-2019, 05:39 AM   #9
Mac VP
Mac VP's Avatar
The socket extractor tool should do the trick. Tap it tightly onto the old bolt head before attempting to turn it. Those things work a wonder. Looks like your old bolt still has plenty of meat left on it for this process.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 07-28-2019, 06:01 AM   #10
big job
big job's Avatar
Sometimes that bolt is stubborn, I tap the pump (all other bolts removed) with a lead
hammer counter clockwise to loosen it up. The bolt usually freezes up to the pump
not the block. works for me
big job is offline   Reply With Quote
Old 07-28-2019, 09:37 AM   #11
Emmit51
Emmit51's Avatar
Thanks for the tips. I’m getting an extractor set and will give it a shot.
Old 07-30-2019, 07:10 PM   #12
Emmit51
Emmit51's Avatar
Thanks JSeery and big_job for the tips - did the trick!
Old 07-30-2019, 09:50 PM   #13
JSeery
JSeery's Avatar
Glade to hear it!
Old 08-01-2019, 04:46 PM   #14
Karl Wolf
Karl Wolf's Avatar
Or, you could center punch the bolt- and use a 3/16" drill to pilot a hole. Then drill the head of the bolt off with a 3/8" bit. After removing the pump there is enough of the bolt left above the surface of the block to use vise grips to remove the rest of the bolt.
Karl
Karl Wolf is offline   Reply With Quote
