Old 05-18-2018, 05:30 PM   #1
fred93
fred93's Avatar
Default 1929 tire questions
Getting ready to purchase new tires for a 29 Tudor. I see lots of options online so I am confused.
What is the correct tire size for the 1929 Model A ?
I see tires out there that have nylon cords--but I remember some cars that I owned back in the day that had nylon tires and they had a tendency to get flat spots whenever the car sat for awhile. It would take some driving for them to get round again. I don't like that situation, so I guess nylon tires are out, unless they have been improved! I called Lucas Tire in CA and asked if the Olympic Tread Blackwall was a nylon cord tire and they said yes it was, but they said that they were NOT having problems with the tires getting flat spots after sitting. Anyone have any feedback on that? https://www.lucasclassictires.com/44...?categoryId=-1
Then I have seen several different sizes as well. 440/450 21 450/475 21
What is the correct size?
Why is there never enough time to do it right, but always enough time to do it over!!!
fred93 is offline   Reply With Quote
Old 05-18-2018, 06:12 PM   #2
WHN
Default Re: 1929 tire questions
We have nylon Firestone’s on our 29. It sits from November until May. We have not had a problem with flat spots. Keep inflated at 35 psi. Enjoy.
Old 05-18-2018, 07:59 PM   #3
Fred K-OR
Fred K-OR's Avatar
I use Firestone whitewalls on both of my 1929's. The seem to work OK. Don't think they are nylon.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 05-18-2018, 08:55 PM   #4
1955cj5
1955cj5's Avatar
I have the Lucas 440/450 21's. They seem to work fine.
I think any bias ply tire flat spots a bit when they are allowed sit for a period of time. ( I have a jeep with NDCC military style tires and it'll bounce you good for a mile or two)
A short drive usually rounds them out.
A few days of sitting does not seem to bother them.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is online now   Reply With Quote
Old 05-18-2018, 09:13 PM   #5
Fred K-OR
Fred K-OR's Avatar
I find that my coupe will have flat spots for a little while when I take off.
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 05-19-2018, 09:06 AM   #6
katy
katy's Avatar
From the Model A Instruction Manual: Tires 21 x 4.50 Balloon.
http://www.motormayhem.net/wp-upload...ion-Manual.pdf
Old 05-19-2018, 09:22 AM   #7
Simonpie
WhenI got my new tires, I wanted to try Blockleys. They didn't make a 4.50-21, but said the 5.25 would shoehorn on and work well. I'd have to say they were right. The tires look like they fit, seem to work well, and are pretty flat across the tread. You can see a slight crowning. I have only done a few trips on them, but haven't noticed flatting while parked.
Simonpie is offline   Reply With Quote
Old 05-19-2018, 10:42 AM   #8
Synchro909
Synchro909's Avatar
Original size is 4.5 X21 but my cars are drivers so I go for roadholding more than appearance. 5.25X21 give better road manners and about 5% higher gearing. I think we’ll worth the extra $.
Old 05-19-2018, 10:44 AM   #9
oldforder
oldforder's Avatar
I have Lucas tires that are almost new,( were on the car when I bought it) and they don't seem to have flat spots after sitting for several weeks at a time during the winter. I do keep them aired up, and in a garage where the temp never gets below freezing, if that makes any difference.
oldforder is offline   Reply With Quote
Old 05-19-2018, 10:26 PM   #10
denniskliesen
denniskliesen's Avatar
I have the Lucas tires too. And they will be the last set I buy. Mine have low miles on them and are going to be replaced soon. No problems with flat spots.
denniskliesen is offline   Reply With Quote
Old 05-21-2018, 04:37 PM   #11
oldforder
oldforder's Avatar
I don't understand. If they have low miles, why are they going to be replaced soon, and why will they be the las set you buy. Are you saying they are good or bad?
Old 05-22-2018, 01:41 AM   #12
denniskliesen
Low miles and worn out. I drive much more in a year than the average Model A owner. I need more than 5,000 miles from a tire before it needs to be replaced.
Old 05-22-2018, 09:08 AM   #13
JohnLaVoy
JohnLaVoy's Avatar
The choices are varied on tires. You need to decide on what you want. Goodyears have the correct size and wear pretty well. If you want mileage get the Excelsior radials you get a 50,000-mile warranty with those.
Our roadster pickup is running the Excelsior tires.
JohnLaVoy is offline   Reply With Quote
Old 05-22-2018, 10:31 AM   #14
denniskliesen
21" wheels are the correct original size for your car. They do not make a recommended radial for 21" wheels on a Model A.
Old 05-23-2018, 01:33 AM   #15
M2M
M2M's Avatar
Wow, 130mph rated Blockley bias ply tyres on a Model A !!!
M2M is offline   Reply With Quote
