Old 01-31-2020, 11:31 AM   #21
Ole Don
Ole Don's Avatar
Default Re: 1955 Ford Ranch Wagon/ Vintage Air Question?
If you dislike the "GM" alternator, call it a John Deere part. Same but different. For the fan, my high compression 312 ran warm in heavy traffic. I found a fan from a Granada with A/C, it had seven blades and cooled much better. All the Fords from the 80's and 90's had the same fan bolt pattern except 429 and 460. Any fan including clutch fans would interchange, just try to use the bolts that came with the fan and spacer you find.
Ole Don is offline   Reply With Quote
Old 01-31-2020, 03:03 PM   #22
dmorge
Just installing the same Gen 4 in my 55 Ranch wagon.I had a under dash unit that would not do the job,I have an aluminium radiator with a Cooling Components electric fan with a 105 amp alternator so cooling was not a problem for a warmed [cam headers 600 holley]272. The unit fit under the dash nice but the glovebox is going to be about 2" deep.Dave
dmorge is offline   Reply With Quote
Old 01-31-2020, 03:47 PM   #23
56sedandelivery
56sedandelivery's Avatar
On the glove box, I just fiberglassed over the glove box because it was in pretty bad shape. Now if I need to cut and fit a A/C it is easy to do.
56sedandelivery is offline   Reply With Quote
Old 02-03-2020, 03:28 PM   #24
grumppyoldman
grumppyoldman's Avatar
My 55 has vintage air and it never get's to 190 in this Texas summer heat, it has a pusher fan in front and two smaller pull fans in back. I'm pretty sure the radiator is larger than the stock one that came in the car. it cools down fast and is colder than my 2016 truck. I tried posting pics, but no luck. Al
grumppyoldman is offline   Reply With Quote
Old 02-03-2020, 04:11 PM   #25
40cpe
40cpe's Avatar
I would like to see pictures of your radiator, fans, and inside unit. If you will send them to me at [email protected] I will try to post them.
Old 02-06-2020, 03:08 PM   #26
poolplayer1
If dmorge and grumppyoldman could post pictures of the Gen4 ac unit on their 55's, both the installation under the hood and also the inside would be great.I hope that both or at least one can post pictures so that we can see how it fit and how you did the installation.
Thanks for posting your pixs.
poolplayer1 is offline   Reply With Quote
Old 02-13-2020, 09:47 PM   #27
harleyjohn45
harleyjohn45's Avatar
I think I lost a little more than half of my glove box. The previous owner installed the A/C.
I just have the regular fan and radiator, it worked fine in Florida. I've since moved to the mountains in NM, I seldom turn the A/C on. I would like a shroud tho.
harleyjohn45 is offline   Reply With Quote
