11-10-2020, 12:04 AM | #1 |
Brake Switch Wiring Connection
The original brake switch on my 49 F1 finally no longer works. In this original switch the prongs have a hole for the wires and grub screws to fasten them.
On this replacement switch how are the wires fastened to the prongs? There are no threaded screws or holes, only 2 grooves in each of the prongs. Thanks in advance. |
11-10-2020, 02:08 AM | #2 |
Re: Brake Switch Wiring Connection
You should be able to get some solder-less connectors that you can crimp onto the ends of the wires. Then push them onto the switch.
11-10-2020, 06:11 AM | #3 |
They're called bullet connectors. Usually, the wires have male ends attached and connect together via a female 'tube' connector. Now you can also just get a female connector type. This is what you need. Commonly available.
11-10-2020, 07:15 AM | #4 |
Female bullet connector is required
11-10-2020, 02:03 PM | #5 |
