Old 07-21-2022, 02:16 PM   #1
bucket-o-rust
Default Late 31 rad shell
I have a late 31 radiator shell with the two removable sections. It is in good condition but it has been taken apart and some of the tabs that hold the two removable sections on are broken off. Is there some way to overcome that problem?
bucket-o-rust is offline   Reply With Quote
Old 07-21-2022, 06:31 PM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: Late 31 rad shell
Good mig welder can fix.
Also less than perfect but use the ones there a silicon seal inside where not seen
I said mig but would opt for tig
Old 07-23-2022, 06:41 PM   #3
bucket-o-rust
Btt
Old 07-24-2022, 10:15 AM   #4
katy
katy's Avatar
See post #2
Old 07-24-2022, 02:55 PM   #5
Kevin in NJ
Some have used silicon to glue them on I would look around for a marine guy and ask if they have a little 3M 5200 as you wont need much. The 5200 sticks much better, but can be pricey to buy a whole tube.
Old 07-24-2022, 08:30 PM   #6
JoeCB
JoeCB's Avatar
Just a "heads up" on the 3M 5200, its very good stuff, sticks to everything and remains flexible ...BUT once you open the tube it will begin curing and can't be saved. I have tried, even putting some excess in a sealed screw top jar, still cures. So getting a dab from a marine guy is unlikely. Maybe, take your parts and ask them to apply some from a job under way.
Joe B
JoeCB is online now   Reply With Quote
