10-21-2017, 05:21 AM | #1 |
spark plugs
what spark plugs do you put for 272 ci yblock ?
10-21-2017, 05:27 AM | #2 |
Re: spark plugs
Lots of folks like Autolite 45 though may be a little hot for extended freeway use.
10-21-2017, 06:22 AM | #3 |
Re: spark plugs
what do you think the 11 RF 18 YC champion
10-21-2017, 11:18 AM | #4 |
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
Re: spark plugs
Bsf, brf, bf -82
10-21-2017, 12:13 PM | #5 |
Re: spark plugs
Those are two different plug heat ranges. Unfortunately modern manufacture Champion plugs rightly or wrongly do not have the reputation they once had. Autolite 45 or BF42 are well suited to these engines, and I've heard good things about NGK plugs.
In most cases the "normal" heat range plug will give good service in a stock engine, unless one is running extended highway use in the summer. Keep in mind a common tuning error is to install a hotter plug when the issue is actually incorrect ignition timing and/or carburetor tuning - jetting, power valve etc. Plug fouling for example. Modern fuels don't color the way leaded gasoline did, either on the plugs or exhaust. They can look somewhat lean and still running very rich. So it's a cut and try method. Make sure you have a good HOT spark ignition, timing curve squared away, and carburetor tuned well before deciding you need a different heat range. |
10-21-2017, 12:23 PM | #6 |
Re: spark plugs
10-21-2017, 12:38 PM | #7 |
Re: spark plugs
i have the autolite 46,i want just change for the best
10-21-2017, 01:22 PM | #8 |
Re: spark plugs
http://www.ford-y-block.com/tuneup.htm
46 are considered "too hot". 45s are good, but a little hot for extended highway use. There is no Autolite 44, and BF32 are pretty much unobtanium (at $2 a plug) now. Don, what is the NGK #? |
10-21-2017, 08:41 PM | #9 |
Re: spark plugs
I have used 46's in my two Y's. That seems to be the recommended plug. Plugs always looked good with a nice tan color on the ceramic.
48 Ford Conv 56 Tbird 54 Ford Victoria Last edited by paul2748; 10-22-2017 at 06:46 PM. |
10-21-2017, 11:18 PM | #10 |
Re: spark plugs
I’ve run NKG’s in everything since at least the mid 70’s. They just seem to work and last. The only exception is my daily drivers with the 50,000 mile plugs. I live with the OEM’s on them.
10-22-2017, 02:09 AM | #11 |
Re: spark plugs
what's motorcraft do you use?
10-22-2017, 07:01 AM | #12 |
Re: spark plugs
I'll go along with BF82, BRF82 and BSF82. That's what Ford went with when they switched to Motorcraft.
Dan Kingman Az. 86409 |
10-22-2017, 08:33 AM | #13 |
Re: spark plugs
what's the reference with NGK
10-22-2017, 09:09 AM | #14 |
Re: spark plugs
NGK AP5FS or APR5FS
The R signifies a resistor plug |
10-22-2017, 07:07 PM | #15 |
Re: spark plugs
I use the Autolite #46's in my '55 Customline with a 272. Car now has a quarter million miles plus on it with the last 90-100K miles being with the 46's. I try to change them out at 40-45K mile intervals and they always look good. The car has electronic ignition which explains the spark plug life. Ted Eaton.
10-22-2017, 07:50 PM | #16 |
Re: spark plugs
Thanks, Ted. So you don't hold with the info provided at the link I posted above. Good to know.
10-23-2017, 07:20 AM | #17 |
Re: spark plugs
The compression ratio is a big player when selecting the heat range for the spark plugs. The lower the compression ratio, then the need for a hotter spark plug. The 272 with 7½-8:1 compression ratio is happy with the 46 Autolites. As the cubic inches goes up, so does the compression ratio when all else is equal. For the 9-9½:1 292's, I'll use the Autolite 45 spark plugs. Ted Eaton.
