Old 07-13-2018, 04:20 PM   #1
Chris Haynes
Chris Haynes's Avatar
Default How to lower the A.
I know there was a thread about this however a search turns up everything else but.
In searching for a 1932-1934 front axle I find them to be made of unobtainium. I have found a '37 front axle. However the spring perches are much further apart than the A and '32-'34. My question is if I fit it with Model A perches and a '37 spring will it work on my A?
Secondly what would I do for the wishbone as the A isn't wide enough and widening it will shorten it.
Should I toss this idea and continue my search for the '32-'34 axle?
TIA for your help.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 07-13-2018, 05:10 PM   #2
harryc
Default Re: How to lower the A.
you can go pretty low by reshaping the springs
harryc is offline   Reply With Quote
Old 07-13-2018, 05:20 PM   #3
pooch
pooch's Avatar
Sounds like you want to do it on the cheap., or you would just buy a dropped axle and bolt it in.
You can easily re-arch the front main spring leaf the opposite way in a shop press to make it a reversed eye, and straighten the other leaves a bit to also lower the whole spring.
Will gain you a 2 inch drop easy.
pooch is offline   Reply With Quote
Old 07-13-2018, 05:20 PM   #4
Bob C
Here are new ones. http://www.posiesrodsandcustoms.com/...y-i-beam-axle/
Bob
Old 07-13-2018, 05:24 PM   #5
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
You can go 32-36 I have another stock 36 axle I might be interested in selling. Not sure of shipping cost etc.
Old 07-13-2018, 07:45 PM   #6
Brendan
Brendan's Avatar
i got a 4 in dropped axle in my car
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 07-13-2018, 09:44 PM   #7
Chris Haynes
By using the '32-'34 axle and reversed spring eyes you will get a 2"drop and still look stock. I have no desire for a dropped axle.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 07-14-2018, 12:50 AM   #8
Chuck Sea/Tac
Once again 32-36 are the same part number
B3020. 37 is part number 78-3010 Interestingly enough there is a larger 32 axle, but it’s not listed in the orange 28 to 37 parts book.
Old 07-14-2018, 04:44 AM   #9
Mike V. Florida
Mike V. Florida's Avatar
These are great answers and on the HAMB forum (sister to this one) they specialize in these kinds of mods. https://www.jalopyjournal.com/forum/...l-hot-rods.57/
Old 07-14-2018, 08:18 AM   #10
updraught
updraught's Avatar
Google "fordbarn model a ford lower front axle"
updraught is offline   Reply With Quote
Old 07-14-2018, 10:07 AM   #11
Kahuna
Kahuna's Avatar
Chris
I may be able to help
PM sent
Jim
Kahuna is offline   Reply With Quote
Old 07-14-2018, 10:29 AM   #12
Dodge
I’ve bought 3 of those axles off of eBay. They come up every once in awhile. Keep looking,
They only hard one to get is the early “heavy” 1932 axle.
Dodge is offline   Reply With Quote
Old 07-14-2018, 10:32 AM   #13
1931 flamingo
1931 flamingo's Avatar
According to David G there is NOT a heavy axle. FWIW
Paul in CT
Old 07-14-2018, 11:16 AM   #14
Jim Brierley
'32-'34 have the same contour, '35 and later have the wider spring perches as you noted. '32 had both the std. and heavy axles. Good luck.
Jim Brierley is online now   Reply With Quote
Old 07-15-2018, 02:23 PM   #15
Chris Haynes
True. But sadly they don't have a SEARCH function.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 07-15-2018, 02:51 PM   #16
redmodelt
redmodelt's Avatar
Don't need a search function on HAMB try this in your google search box;
hamb; dropped axle
I just tried it and a whole bunch of links to HAMB and dropped axle.
Works with fordbarn; xxx too.
Old 07-15-2018, 03:51 PM   #17
Chris Haynes
hamb; dropped axle
Thank you. But I am looking for a stock axle, not dropped.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 07-15-2018, 04:00 PM   #18
wensum
wensum's Avatar
I am running a '32 front axle which gives a 1 1/2" drop but it also brings the tie rod that much closer to the chassis and under extreme conditions the tie rod rubs on the chassis. I did have a 4" dropped axle, but that caused all sorts of problems with the tie rod and a goose necked tie rod causes all even more problems. Unfortunately it would appear that no-one makes dropped steering arms to fit the Model A Stub axle.
Heating the original steering arms to lower them has the effect of moving the ball joints closer to the axle centre line and that makes fitting the tie rod very difficult.
Bob Drake sells perch bolts that enables you to keep the Model A Brakes with the '32 axle.
wensum is offline   Reply With Quote
Old 07-15-2018, 04:44 PM   #19
Chris Haynes
Wensum,
Thanks for your knowledge. My A has already received juice brakes.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 07-15-2018, 07:40 PM   #20
Sparky
Sparky's Avatar
Sure it does, look for the tab with the picture of a magnifying glass
File Type: jpg 342C6FAE-1481-4C1F-B7C7-D3CB01EFE969.jpg (20.1 KB, 26 views)
Sparky is offline   Reply With Quote
