12-01-2012, 04:53 PM | #1 |
Paint and overspray on woodframe car
What do you guys do when painting a wood subframe car. My understanding is that the top side of the subframe should be sprayed lower body color. However the local paint shop is advising me that common single-stage urethane paints will dissolve whatever common wood preservative that I may use for the wood sills. How do you approach this ? Should the wood subframe really be painted body color, or should it be masked off during spray painting ?
12-02-2012, 01:48 AM | #2 |
Re: Paint and overspray on woodframe car
It is my understanding that urethane can be used as a wood preservative, usually clears on the exposed wood in ute (pick-up) trays, so I don't see colours being any different. I'm sure others will chime in if I'm incorrect.
12-02-2012, 05:32 AM | #3 |
My thoughts are the same as Dave's.
12-02-2012, 06:53 AM | #4 |
I am not sure of the translation of the word "common" but if it is a catalyzed (two-part) wood preservative, then a catalyzed color coat will not affect it. We use a single-stage polyurethane to protect the wood but it is thin enought that it absorbs into the pores of the wood so the poly does not release when a colored 2k urethance is added. If you are still concerned, just fog a light coat of semi-gloss Black 2k urethane paint onto the wood to give the foundation for the top coat
12-02-2012, 11:23 AM | #5 |
Terry |
