Old 01-02-2018, 08:02 PM   #1
Standing Elk
Default Brake question
I am rebuilding the brakes on my 30 coupe. When I start reassembling all the new parts on the backing plates should I put a little grease on the pins, wedges, rollers and adjusters or leave them dry?
Standing Elk is offline   Reply With Quote
Old 01-02-2018, 08:08 PM   #2
wingski
wingski's Avatar
Default Re: Brake question
Absolutely, put some grease on them. I still prefer the graphite grease even though it is the messiest stuff around. I just finished scrubbing my hands again with Lava and Boraxo because of my rear brakes.
Mike
wingski is offline   Reply With Quote
Old 01-02-2018, 08:14 PM   #3
Licensed to kill
Licensed to kill's Avatar
I can't answer what you SHOULD do but what I did was I put spray on grease on the roller axles and chassis grease on the adjusting wedges and filled the adjusting cavity, where the cam resides, with chassis grease. I left all of the brake shoe pins dry.
Licensed to kill is offline   Reply With Quote
Old 01-02-2018, 08:51 PM   #4
1955cj5
1955cj5's Avatar
I also used grease on all the moving brake parts, pins, wedges etc...
I used this stuff.....I bought it locally, probably O'reillys... this link is just an example...
https://www.zoro.com/crc-synthetic-b...yABEgK3pvD_BwE
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is online now   Reply With Quote
Old 01-02-2018, 09:26 PM   #5
SeaSlugs
SeaSlugs's Avatar
dont forget anti sieze on the adjusting wedge threads.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 01-02-2018, 09:41 PM   #6
Standing Elk
Thanks everyone I was thinking the same thing but wasn't sure.
