Old 05-09-2021, 09:33 AM   #1
Veeder
Default 41 transmission reverse idler gear play ?
Can anyone give me a sense of how much play I should have between the reverse idler gear and shaft? They don't sell replacement bronze bearings so I not sure I want to spend $$ on a new gear. The shaft has only slight wear which is bearably noticeable. Considering that this thing runs 600 weight oil I'm not sure how picky I need to be??
Bob
Veeder is offline   Reply With Quote
Old 05-09-2021, 11:56 AM   #2
alanwoodieman
Default Re: 41 transmission reverse idler gear play ?
roll shaft 180 degree from where it was and use it.
Old 05-09-2021, 03:37 PM   #3
jimvette59
jimvette59's Avatar
It looks like Revers Idler bore .749, Counter shaft .745, Reverse idler shaft .746,
Taken from a posting on the HAMB. Jim T.
jimvette59 is offline   Reply With Quote
Old 05-09-2021, 04:05 PM   #4
Veeder
Perfect guys thanku both!! Looks like it's designed to have some play thk you
Old 05-09-2021, 04:19 PM   #5
1939mars
1939mars's Avatar
You mention 600 wt oil in your post. The transmission should be getting 90 wt. I had heard somewhere that 600 was correct as well but found this in my '39 manual and was chastised (nicely) by some old timers for using it. Switched to 80/90 wt. and run it year round.
1939mars is offline   Reply With Quote
Old 05-09-2021, 06:22 PM   #6
Veeder
Oh wow let me go back and look at a few things - no wonder it didn't leak - lol Seriously I'll dig into this a bit, I also have the container somewhere that I used last year and see what was.
