Old 04-26-2023, 07:08 PM   #61
Model A Ron
Model A Ron's Avatar
Default Re: MMO in the Gas
I have not used Seafoam in my Model A but I have only heard good things about it.
Model A Ron is offline   Reply With Quote
Old 04-26-2023, 07:23 PM   #62
Dino's A
Dino's A's Avatar
I use it in the gas to attempt to put some kind of layer of oil
to coat the tank. The old timers in my club told me it was good
stuff, and I trust them. I also like the smell of it.
1928 Roadster Pickup
1930 Tudor
1943 Ford WWII Jeep
1968 Taco Minibike
Member, Santa Anita Model A's
Arcadia Ca.
Dino's A is offline   Reply With Quote
Old 04-26-2023, 07:32 PM   #63
GPierce
GPierce's Avatar
MMO use is wide spread in the antique and classic aircraft community to prevent valve sticking caused by the high lead content in todays 100 octane leaded fuel. Known as AVGAS.
The low or no lead 80 octane is no longer available.
MMO is available from aviation supply houses.
https://www.aircraftspruce.com/catal...loilgallon.php
Be sure to scroll down and read the OVERVIEW
GPierce is offline   Reply With Quote
Old 04-27-2023, 05:07 AM   #64
Werner
Werner's Avatar
Hey,
please tell me, what's "wintergreen oil"?
Thanks in advance,
Werner
An 1946: Very nice old rare airplane!
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 04-27-2023, 07:30 AM   #65
jack backer
I’m curious to the proven effects. Sure, if you put oil in the fuel it will provide “top end lubrication” but why do you need top end lubrication? We are discussing a simple low compression engine with wide piston rings.. upper cylinder lubrication occurs naturally with it.. oil leakage by the rings is unstoppable.extreme upper cylinder/ combustion chamber temperature which strips this lubrication, and MMO lubrication is mainly caused by the manual spark control, engine timing is almost never correct, especially accelerating. If it makes you feel good do it, petroleum distillates with detergent is handy around the shop.
jack backer is offline   Reply With Quote
Old 04-27-2023, 09:16 AM   #66
Jemelton#
Jemelton#'s Avatar
Along with using MMO in my 29 Tudor I find that it makes a good air tool oil!
Jemelton# is offline   Reply With Quote
Old 04-27-2023, 10:49 AM   #67
stickshift
stickshift's Avatar
Top end lubrication usually refers to in-head valves and valvetrain. Ford was one of the last companies to switch over from flatheads. Chevrolet had their in-head valve six cylinder in 1929. Rambler still made flatheads 'till 1965.
Stickshift
1915 Model T touring
1931 Ford Model AA Flatbed
stickshift is offline   Reply With Quote
Old 04-27-2023, 11:55 AM   #68
jack backer
I’m referring to upper cylinder lubrication, a slight amount of mmo in the fuel or a slight amount of oil in the combustion chamber, extending valve seat life, or so they say.. didn’t mean to mislead..in my opinion you could use ATF, it’s a fine distillate with a solvent/ detergent additive..or don’t use anything..
Old 04-27-2023, 12:36 PM   #69
Terry, NJ
Terry, NJ's Avatar
Originally Posted by Werner View Post
Hey,
Thanks in advance,
Werner
Werner, There is a small Plant with little white berries (edible) that grows in our woods here. The name of this plant is Wintergreen and it has a strong, yet pleasant taste and smell. It's a sort of Menthol. It is the smell that they've synthesized and are using to cover the smell of the Paradiclorobenzene. Perhaps I'm wrong, perhaps it does contribute more than a cover smell to the whole concoction.
Terry
Terry, NJ is offline   Reply With Quote
Old 04-27-2023, 03:55 PM   #70
SAJ
SAJ's Avatar
Werner, wintergreen oil contains methyl salicylate. An ester of salicylic acid and methanol. It is a good wetting and creeping agent on metals, smells nice and is useful as an embrocation on the human body to relieve pain in tired muscles. It is related to aspirin (acetyl salicylic acid) in the way it works for muscular pain relief.
It also works in the vapor phase to soften hard rubber in articles like go-kart tyres, to give better grip for racing. Possibly made illegal now in the go kart racing fraternity
Is that too much information?
SAJ in NZ
SAJ is offline   Reply With Quote
Old 04-29-2023, 12:15 PM   #71
Phil Brown
Phil Brown's Avatar
I've been following along and this has been my thoughts as well. Most of the time I spend trying to keep oil OUT of the combination chamber
Phil Brown is offline   Reply With Quote
Old 04-30-2023, 11:36 AM   #72
duke36
Some use ZDDP zinc additive for flat tappet motors since zinc is banned from fuels due to catalytic convertor issues with zinc. If there is test data for all these additives, it would be good to see them.
duke36 is offline   Reply With Quote
Old 04-30-2023, 01:26 PM   #73
J Franklin
J Franklin's Avatar
With the advances in AI could you believe test data? At least MMO admits there is mystery!
Old 05-01-2023, 08:21 AM   #74
[email protected]
modela@aol.com's Avatar
My Grandfather and Father built a corner Gulf gas station before WWII in Boone County, IL. My Father shared stories of how a lot of local car owners would bring their cars in to be "de-carbonized" .. They would tell the owner to give them a day to do the work of taking the head (s) off. Then they would coat the piston tops and the heads with MMO and let it sit overnight. The next morning they would come in and use shop rags to wipe the pistons and heads completely clean . Easy Peezey.... No brass wire brusheswere needed.
modela@aol.com is offline   Reply With Quote
Old 05-01-2023, 09:05 AM   #75
jack backer
A teaspoon of un cooked rice sprinkled it no the carb at 1200 rpm decarbonizes in a snap
Old 05-01-2023, 11:25 AM   #76
stickshift
stickshift's Avatar
I heard the same thing about Bon Ami, not sure I would want to try it though.
Stickshift
Old 05-01-2023, 06:06 PM   #77
Synchro909
Synchro909's Avatar
Bon Ami to settle in new rings (it is abrasive). Rice would ricochet around the combustion chamber and remove carbon like sand blasting it.
Another way to remove carbon is to spray water in the carburettor intake till the motor stats to miss. Then stop till it runs smooth again. Then, spray again only more till the engine stops. Leave it overnight and when it is run next morning, the carbon will vanish. This works by dampening the carbon and allowing the water to penetrate it before starting the motor. The sudden, extreme heat of combustion causes the water to explosively turn to steam, blowing the carbon off the chamber walls and out the exhaust. Yet another way is remove he head and physically do it but that is hard work.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 05-01-2023, 06:21 PM   #78
GPierce
GPierce's Avatar
A newly rebuilt engine running in as test cell with high crankcase pressure caused by blow-by from rings not seated were cured by a handful of bon-ami thrown into the intake. You could the crankcase pressure drop immediately.
I had an Opel Kadet leaking water into one cylinder while parked. It ran fine. I pulled the head and found exactly what Synchro909 explained; a perfectly cleaned head, valves and piston.
Old 05-01-2023, 09:07 PM   #79
stickshift
stickshift's Avatar
This makes sense with the water. I remember in the early to mid-seventies when the oil embargo caused gas prices to go up to 50 cents a gallon. People were hooking up water injection to their engines so they could run cheaper gas. It prevented detonation and improved mileage. I guess kept the cylinders clean too. I don't know why people stopped doing this. I remember seeing the kits in Warshawsky and JC Whitney catalogs.
Stickshift
Old 05-02-2023, 05:04 AM   #80
jack backer
If you really want to clean it up instead of using water in the vapor draw system use ethanol.. did that on a 400M ford V8.. turned the tail pipe white.. noticeable increase in performance.
