04-21-2017, 09:10 AM | #61 |
Re: Taking a break for some brakes.
04-21-2017, 11:34 AM | #62 |
I sent the stuff Fed Ex, $100 insurance per box included. Since they were all worn out and most things were being replaced, I thought that was adequate. They came back UPS, not sure what Randy does on his end. I have collected a couple of times from UPS shipping damage, USPS... not so much.
04-21-2017, 12:10 PM | #63 |
"USPS... not so much." Paraphrasing Ernestine the Bell Telephone operator on "Laugh In":
"We're the government. We don't care. We don't have to." Marshall |
04-21-2017, 03:59 PM | #64 | |
Know how to downshift from high to second & even second to first! IT CAN SAVE YOUR LIFE---Trust me & PRACTICE-PRACTICE-PRACTICE!!! Bill Safe
04-22-2017, 03:54 PM | #65 |
At this stage of the game, I'm pretty sure one of my new brake linings either didn't get arched, or it didn't get arched correctly. I mentioned earlier that one of the linings was a lot thicker than the others, and after thinking about some of the "on the car" brake shoe arcing I've seen in Model A videos, it dawned on me that the shoe linings should create a round circle (DUH!). I made a little wire gauge, wrapped around the spindle where the inner bearing sets and slowly spun it around. The side that works is round, the side giving me trouble follows along the arc of the rear shoe just dandy, but the front one (that looks extra thick) keeps getting thicker from middle towards the bottom. Heck Darn!
04-22-2017, 04:04 PM | #66 |
There used to be a shop here that fit the shoes to the drums, but it's long gone... Randy has them now....back next week I hope...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 Last edited by 1955cj5; 04-22-2017 at 07:04 PM. |
04-22-2017, 08:32 PM | #67 |
I'm going to move on to the rear brakes for now, would be nice to have a little progress. Trying to remove the rear radius rods now. The nut came off reasonably but the bolt won't budge.
04-22-2017, 08:36 PM | #68 |
Art, you might just need a wee bit larger hammer.
04-22-2017, 09:08 PM | #69 |
I guess with new drums and new shoes, the shoes don't have to be arced to a specific drum. Just arced to the proper "new drum" radius.
You may want to try your wire gauge on all assembled shoes to make sure the bad one is the only bad one. Also, maybe try another shoe in its place on the same backing plate to make sure it isn't the backing plate, drum, or hardware that is tweaked. On the radius rods, I assume you mean the bolt where the rods come together under the front of the drive shaft? If so, do you have the 4 bolts holding the radius rods at the backing plate loose or off? If not, they could be binding the front bolt.
All steel from pedal to wheel |
04-22-2017, 09:10 PM | #70 | |
I used a 1/2" air impact wrench to remove mine. Do you have the rear of the radius rods loose? Maybe one is binding. I wired mine to the running board bracket. Sent from my iPhone using Tapatalk
Our 1931 Station Wagon: Originally restored in 1962, redone in the early 1980's, brought back to life in 1997 and refreshed in 2016/2017. Check out the progress at a31woody.com |
04-22-2017, 09:43 PM | #71 |
The rear brakes and backing plates are still off, so nothing holding radius rods at the back. PB blaster currently working its magic. Would make installing the rears a lot easier if they were out of the way.
04-23-2017, 12:01 PM | #72 |
04-23-2017, 03:02 PM | #73 |
Hello Art,
I believe your shoes were arced OK, I think what you have is a shoe that was bent deliberately at some time in its life changing the arc to fit a worn drum, ask me how I know, I hand arced my shoes, and found on 1 shoe that both ends were thinner than the middle, this also changes its pivot points so both shoes do not adjust equally. I do believe that Mr Williams or Buster will chime in on this one, I am sure that's where I learned it from.
Nothing can be made foolproof, ---- fools are ingenious bastards. |
04-23-2017, 03:16 PM | #74 | |
I had a similar issue getting the locking pins out for the front brakes, of course when someone else came to help out they'd been soaking in PB Blaster for a week and flew right out.
"It is much easier to call someone else a genius than admit to yourself that you are lazy." - Dave Gingery |
04-23-2017, 06:49 PM | #75 | |
https://www.youtube.com/watch?v=0iHlBFw5UfA |
04-23-2017, 07:14 PM | #76 | |
I was able to slip the rear assemblys out pretty easily after removing the emergency lever and lifting the radius rods a little, but they come from Randy all assembled so would like to put them back that way. I have the radius rod removed on one side now, the bolt at the torque tube still won't budge. PB Blaster is dripping all kids of nasty-rusty looking goo. The threads were not in good shape either so it needs replaced. PB... whack on it... rinse and repete, resistance is futile. |
04-24-2017, 12:34 AM | #77 |
I just installed a Flathead Ted's kit (that I won at the OC Pancake Breakfast, Yeah!). Even with the deluxe kit I found it is better to have the Rear Brake Roller Track flat and within spec. On the front it doesn't matter because the Front Roller Track is no longer used.
04-24-2017, 08:29 AM | #78 |
I've yet to order the deluxe kit from NZ. For those that are interested, these pins are supposed to be turned to lift or lower the rear shoes, from what I gather.
04-24-2017, 01:44 PM | #79 |
Yahoo! I've managed to turn the torque-tube / radius rods bolt two full turns today! With a 2 ton floor jack pushing on a 1/2 inch breaker bar! Can't turn it by hand yet, but it won't be long now.
Randy is sending me a couple new brake shoes, probably only need one. He did offer to build me up another backing plate ass'y, but I don't think that's necessary. |
04-24-2017, 03:04 PM | #80 | |
Flathead Ted's kit works great but it is designed to be added to a good working stock braking system. Sorry Art for the detour. Last edited by Y-Blockhead; 04-24-2017 at 03:26 PM. Reason: Punctuation... |
