Old 05-09-2014, 10:04 PM   #1
midgetracer
midgetracer's Avatar
Default Kelsey wire bent spoke wheels
I found a pair of Kelsey Hayes bent spoke wheels that are 16''X4" and look exactly some Ford ones I have, but this set has a 5 on 4.5 bolt pattern. They do not have the extra hole that Plymouth used. Anyone have any idea what these were from?
midgetracer is offline   Reply With Quote
Old 05-09-2014, 10:29 PM   #2
deuce lover
deuce lover's Avatar
Default Re: Kelsey wire bent spoke wheels
Picture would help
deuce lover is offline   Reply With Quote
Old 05-10-2014, 01:23 PM   #3
midgetracer
Here are the pictures
Old 05-10-2014, 04:38 PM   #4
Lanny
Lanny's Avatar
One possibility would be early 30's Studebaker & Rockne.
Here is a pic of a '32 Stude, I think they had 4 1/2" bp.
click on picture to Enlarge
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 05-10-2014, 04:47 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
I'd betcha that those are bigger than 16 X 4. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 05-10-2014, 04:59 PM   #6
Lanny
Lanny's Avatar
You could be correct, but I just listed that picture as a close reference,
and I also mentioned the Rockne, as they were close to the size of '33
and '34 Ford cars, and should have a simular wheel, which could be 16x4.
Old 05-10-2014, 06:23 PM   #7
deuce lover
Its not a Ford wheel.Hub is totally different.
Old 05-10-2014, 06:32 PM   #8
CrazyBackyardBuilder
CrazyBackyardBuilder's Avatar
33 & 34 Fords had 17 inch wheels.
CrazyBackyardBuilder is offline   Reply With Quote
Old 05-10-2014, 08:02 PM   #9
Lanny
Lanny's Avatar
I know that '33 and '34' Fords have 17" wheels, but I don't know what size wheels
the Studes or Rocknes had, I'm simply trying to give the OP an idea of a car model
that has Simular looking wheels as the ones in his pictures, and could
Possibly be what his are, OR NOT.
Old 05-10-2014, 08:07 PM   #10
midgetracer
The stud holes are slightly larger than the Ford style. Any possibility that these might fit on 49 and newer drums? They seem to require the same spacers as are required using 35 Ford wheels on 40 Ford drums.
Old 05-11-2014, 02:32 AM   #11
flatrod
flatrod's Avatar
I have a pair just like them. Sure wish I knew what they are. They bolt right on my Mustang II disc brakes with no clearance issues. They did have a small dual pin stripe line around them when I got mine. No marking other then saying Kelsey Hays and size, 16 x 4.
flatrod is offline   Reply With Quote
Old 05-11-2014, 04:19 AM   #12
BILL WZOREK
BILL WZOREK's Avatar
I had a old timer tell me that if I courd learn just one thing a day I could die a very smart guy soooooooooooooo.
today I would like to learn what is a Rocknes ??????
THANKS
The student in the back row ~~~~
BILL WZOREK is offline   Reply With Quote
Old 05-11-2014, 05:06 AM   #13
B-nut
Knute Rockne was a famous football player that Studebaker named a car after.
B-nut is offline   Reply With Quote
Old 05-11-2014, 06:49 AM   #14
Elmo Rodge
Elmo Rodge's Avatar
Rockne's had 18" wheels and Studebaker 17" in 1933/34. Those were the only years for wires. Wayno
Life is not a spectator sport.
Elmo Rodge is offline   Reply With Quote
