Old 11-15-2013, 11:39 PM   #1
Rowdy
Default What is This Bracket for?
Got the 59A engine put in the parts shed today. I am curious what the tall bracket on the left head is for? Looks to be a factory made mount for something. Thanks Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 11-15-2013, 11:45 PM   #2
ford38v8
ford38v8's Avatar
Default Re: What is This Bracket for?
Confirm with someone else, but I beleive that to be the mounting bracket for a heavy duty oil bath air cleaner, optional Ford equpment for dusty conditions. The can mounted within the radius of the mount, with a horizontal duct from there to the carburetor air horn.
Alan
Old 11-15-2013, 11:57 PM   #3
Rowdy
That makes sense, I may even have the air cleaner for the bracket. It was mounted on a AA chassis that had been made into a haysweep. The top of it can be seen in this pic. I will have to see how it compares next week while out at the farm moving parts around before the snow hits. Rod
Old 11-16-2013, 03:34 AM   #4
flatheadfan
flatheadfan's Avatar
Yup. That's what it is, an air filter bracket. I have one on my '35.
Tom
flatheadfan is offline   Reply With Quote
Old 11-16-2013, 10:58 AM   #5
Rowdy
Thanks, that air cleaner looks like the same as what I mentioned above. Will see if the two bolt together. Rod
Old 11-17-2013, 12:54 PM   #6
36 CS
That is the type air cleaner I would like to install on my 41. Anyone have one on here or know where I might find one or know what to expect to pay for one?
36 CS is offline   Reply With Quote
Old 11-17-2013, 01:17 PM   #7
Rowdy
After I confirm the filter is correct for the bracket I will have this for sale. I plan on rumming 2 97's and no hood I have no use for it. Likely it will be Tuesday or Wednesday before I make it to the farm to take off the filter and look over the condition and make sure it is correct. PM me sometime this weem. Rod
Old 11-17-2013, 04:40 PM   #8
Mart
Mart's Avatar
The front cover may have been changed if it is a 59A. It looks like a 3 bolt. It should be a 2 bolt if a 59A. Could it be an earlier motor? I know you like to know what you have.
Mart.
Old 11-17-2013, 05:20 PM   #9
Rowdy
Beings this was removed from a 39 truck it had the helmet distn which I removed before pulling the engine. I have the correct distributor etc for the 59A. Rod
Old 11-21-2013, 12:02 AM   #10
Rowdy
I brought the bracket and the other filter home from the farm today. It looks like there were atleast 2 styles of these filters. One that bolted to the bracket and one that was spotwelded to the bracket. The one that is spotwelded must be for a 21 stud as it has a different bolt pattern. Too bad the bottom is rusted out of it. Rod
Old 11-21-2013, 12:30 AM   #11
Tinker
Tinker's Avatar
Never seen one like that... Not that, that means anything... Nice find!
Old 11-21-2013, 12:49 AM   #12
Rowdy
Up until last week I had not seen either style or simply didn't pay attention to oddities like this. When I see a flathead I am always more curious if it is a 21 stud and which carb and seldom give the aircleaner configuration a second look other than to try to see under it. Rod
Old 11-21-2013, 01:26 AM   #13
Mike B
Don't toss it just because it's rusted out...check the diameter of it, bet you'll find something that could be used to repair it.
Mike B is offline   Reply With Quote
Old 11-21-2013, 01:37 AM   #14
Rowdy
Thanks, no intentions of tossing, someone might need one some day. I don't toss much. Just taking account of what I have as someone above said they wanted one. Rod
