05-09-2014, 10:04 PM | #1 |
Kelsey wire bent spoke wheels
I found a pair of Kelsey Hayes bent spoke wheels that are 16''X4" and look exactly some Ford ones I have, but this set has a 5 on 4.5 bolt pattern. They do not have the extra hole that Plymouth used. Anyone have any idea what these were from?
05-09-2014, 10:29 PM | #2 |
Re: Kelsey wire bent spoke wheels
Picture would help
05-10-2014, 01:23 PM | #3 |
Here are the pictures
05-10-2014, 04:38 PM | #4 |
One possibility would be early 30's Studebaker & Rockne.
Here is a pic of a '32 Stude, I think they had 4 1/2" bp. click on picture to Enlarge
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
05-10-2014, 04:47 PM | #5 |
I'd betcha that those are bigger than 16 X 4. DD
05-10-2014, 04:59 PM | #6 |
and I also mentioned the Rockne, as they were close to the size of '33 and '34 Ford cars, and should have a simular wheel, which could be 16x4. .
05-10-2014, 06:23 PM | #7 |
Its not a Ford wheel.Hub is totally different.
05-10-2014, 06:32 PM | #8 |
05-10-2014, 08:02 PM | #9 |
I know that '33 and '34' Fords have 17" wheels, but I don't know what size wheels
the Studes or Rocknes had, I'm simply trying to give the OP an idea of a car model that has Simular looking wheels as the ones in his pictures, and could Possibly be what his are, OR NOT. . .
05-10-2014, 08:07 PM | #10 |
The stud holes are slightly larger than the Ford style. Any possibility that these might fit on 49 and newer drums? They seem to require the same spacers as are required using 35 Ford wheels on 40 Ford drums.
05-11-2014, 02:32 AM | #11 |
I have a pair just like them. Sure wish I knew what they are. They bolt right on my Mustang II disc brakes with no clearance issues. They did have a small dual pin stripe line around them when I got mine. No marking other then saying Kelsey Hays and size, 16 x 4.
05-11-2014, 04:19 AM | #12 |
I had a old timer tell me that if I courd learn just one thing a day I could die a very smart guy soooooooooooooo.
today I would like to learn what is a Rocknes ?????? THANKS The student in the back row ~~~~ |
05-11-2014, 05:06 AM | #13 |
Knute Rockne was a famous football player that Studebaker named a car after.
05-11-2014, 06:49 AM | #14 |
Rockne's had 18" wheels and Studebaker 17" in 1933/34. Those were the only years for wires. Wayno
Life is not a spectator sport. |
