06-26-2019, 08:16 PM | #21 | |
Re: Amp test on the generator
Did you notice his daily summer driver out back of the store: https://www.google.com/maps/place/Ca...4d-105.3362368 Last edited by Merc Cruzer; 06-26-2019 at 08:25 PM. |
06-26-2019, 09:56 PM | #22 |
Little less then a fordbarn topic, but when you put a high current/amp sound system (1000w on...(amps x voltage = watts)) in a vehicle, you are best to get a battery that is suitable to the draw. Upping the alternator output (in most cases) is not needed. But it will certainly knock out a regular battery fairly quickly as it can't handle the exchange and it will run your normal alt ragged. If your generator is not at full normal expected capacity, that's not good.
Nice you found a Great place and a goto guy also. . Last edited by Tinker; 06-26-2019 at 10:56 PM. |
06-26-2019, 10:14 PM | #23 |
Yes I read your post above but you really don't know how he tested it. It should do well over 33 amps if tested without the voltage regulator and the test bench motor drives it fast enough. If you dismantle the gen and polish the comm and check brushes etc then that's OK but there may be more problems than that. Some test gear is required to test the armature an field coils. And some experience in this field would be helpful. Yes I did notice his improved model A coupe parked outside his shop, looks good. Good luck with your generator repairs. Regards, Kevin.
06-27-2019, 09:13 AM | #24 |
A person should have access to a good growler set and a machine to true up and undercut the mica on the armature if needed. The growler sets usually have the tester for the armature segments built in. A good multi-meter can test the field coils and terminals for good insulation.
My Lincoln Mercury Overhauls Manual for the 49 thru 51 models illustrates the use of the Sun equipment that was used back in the day for all the electrical system tests ans adjustments. I'm sure the later manuals do too. Ford was publishing good manuals in this time frame. |
06-27-2019, 05:54 PM | #25 | |
