Old 04-30-2019, 09:22 AM   #1
SpeedC
Default Rear suspension
I recently purchased a 31 A coupe, that has many modifications. My question is the rear suspension. Whenever i hit uneven surfaces the rear suspension tends to make quite a bit of noise. I went underneath and it looks like the top of spring hits the top of the vehicle. How can i go about this? Thanks
SpeedC is offline   Reply With Quote
Old 04-30-2019, 09:25 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Rear suspension
Originally there was a piece of frame webbing riveted to the body to stop metal to metal contact
Old 04-30-2019, 09:37 AM   #3
Joe K
Joe K's Avatar
It may well be "spring shackle connection" wear. The spring perch which is part of the rear trumpet housings is prone to wear because of the constant loading of the car. I have seen these shackle connection points worn practically through to dropping the shackle.
A lot of wear and lack of grease may be what you're hearing?
Joe K
Shudda kept the horse.
Old 04-30-2019, 10:09 AM   #4
katy
katy's Avatar
WOW, I don't think it should go quite that far.
Old 04-30-2019, 11:27 AM   #5
Jim Brierley
If you take the spring out, check to see that the top leaf is rounded to fit into the crossmember.
Old 04-30-2019, 12:00 PM   #6
SpeedC
Thank you all for the replies. I forgot to mention the suspension is not original.
Pictures
https://photos.app.goo.gl/QHYkyHa9j6prq6As9
Old 04-30-2019, 12:07 PM   #7
wmws
All bets are off. Can't really help you with that setup but something must be loose up there.
wmws is offline   Reply With Quote
Old 04-30-2019, 02:14 PM   #8
1931 flamingo
1931 flamingo's Avatar
referring to the "modifications", a picture would help.
Paul in CT
Old 04-30-2019, 02:26 PM   #9
d.j. moordigian
d.j. moordigian's Avatar
Pictures
You can see were the 4 bar upper mount is hitting the rear crossmember,
which is in the 3rd. photo. Get under the car and spend some time looking..
d.j. moordigian is offline   Reply With Quote
Old 04-30-2019, 03:26 PM   #10
Joe K
Joe K's Avatar
Someone at HAMB probably has had similar issues.
Joe K
