05-23-2013, 11:31 AM | #1 |
radius ball
if I were to weld in a new radius ball how accurate does the hole have to be drilled. It would seem that a few degrees off would change the caster of the front end. The same could be said for using the radius ball washer, putting it on top as apposed to putting it on the bottom of the radius ball. Has anyone done the math to see how accurate this has to be?
05-23-2013, 12:29 PM | #2 | |
Re: radius ball
05-24-2013, 06:56 AM | #3 |
Re: radius ball
I appreciate the response Brent. When you say the ends of the axle are not the same do you mean that the king pin angle is different so that caster on each wheel is different? Where does the spacer washer go, top or bottom?
05-24-2013, 07:00 AM | #4 |
Re: radius ball
What I am saying is many axles were abused over the years as owners hit things, or used a chain around an axle to pull things (out). Rarely do I ever find an axle that does not need straightening, and often times one end is tweaked differently than the opposite end due to this abuse.
05-24-2013, 10:59 AM | #5 |
Re: radius ball
Are you sure you need the washer?
I thought my first Model A was quite worn, but when I removed the rubber cover and put the correct plates kit back on, the space between the plates was at least 1/8", so I was good to go. |
05-24-2013, 11:26 AM | #6 |
Re: radius ball
05-24-2013, 09:49 PM | #7 |
Re: radius ball
The radius of the radius rod is 36" from the axle to the ball. This gives an effective diameter of 72". The circumference of a circle is pi x dia, so the circumference is 246". A circle has 360 degrees. If we divide 246 with 360, we get 1 degree equaling .68". or 1" equaling 1.47 degrees. A 1/4" variation will change the king pin angle by .367 degrees, and a 1/2" variation will change it by .73 degrees.
05-24-2013, 10:07 PM | #8 |
Re: radius ball
Brent - How do you straighten an axle?
05-24-2013, 10:30 PM | #9 |
Re: radius ball
05-25-2013, 05:52 AM | #10 |
Re: radius ball
05-25-2013, 01:05 PM | #11 | |
Re: radius ball
https://www.fordbarn.com/forum/showthread.php?t=103130
05-25-2013, 05:16 PM | #12 |
Re: radius ball
Caster angle is not critical. It can vary a few degrees and as Brent mentioned, weight of passengers spring sag, bouncing up and down all add to caster angle change. Positive caster gives the vehicle the ability to track straight down the road and return straight after a turn. The more positve the caster angle the more it wants to track straight.
