04-12-2020, 06:28 PM | #1 |
Radiator shroud fit question
Has anyone had experience with installing the ‘28 shroud (original) with a reproduction radiator? The radiator in my 28 appears to be the low price version available from Mac’s. I’ve done a bunch of measuring and looks like the bottom tabs on the radiator are in the way- I’m curious if the tabs on an original or a Brassworks show quality radiator are in a different spot or orientation?
Thanks! |
04-12-2020, 06:36 PM | #2 |
Re: Radiator shroud fit question
It’s been a while, but it was difficult aligning the shroud tabs on my radiator. I don’t know what brand the radiator is, but I gave up in the end and used black zip ties at the bottom.
04-12-2020, 07:32 PM | #3 |
The radiator had been replaced on my ‘28 Sport Coupe. I bought a new outer shroud. I had to trim (cut) the lower section a little bit adjusting it to fit in further- closer to the radiator, grind a small piece of each side of the lower radiator brackets and redrill the four mounting bolt holes. I still have not permanently mounted it back on again - I’m doing a complete body off. Things have pretty much stopped right now.
Dave |
04-12-2020, 07:39 PM | #4 |
Opps... l was refusing to the outer radiator chrome cover.
05-05-2020, 02:12 PM | #5 |
