Old 04-20-2021, 03:53 PM   #1
13
13's Avatar
Default Frame help needed (Everett, WA)
Hey everyone, I'm hoping to find in the Everett WA area, someone who has a bare 29-31 frame I can take some measurements from, specifically from the cowl forward. Please do not refer to the Westcott drawing, it contains conflicting dimensions. Thank you ��
13 is offline   Reply With Quote
Old 04-20-2021, 06:05 PM   #2
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Re: Frame help needed (Everett, WA)
Aren’t all frames the same basic measurements, except for body mounting brackets?
Old 04-20-2021, 07:43 PM   #3
13
13's Avatar
Likely, could also measure a 30-31. Updated criteria
Old 04-21-2021, 11:38 PM   #4
13
13's Avatar
Anyone?
Old 04-22-2021, 09:18 AM   #5
SSsssteamer
SSsssteamer's Avatar
Due to the 1930 - 1931 taller radiator, and the 1928 - 1929 shorter radiator changes, there is a difference in the radiator mounting areas between the 1929 and 1930 frames. All of my frames have bodies mounted on them.
SSsssteamer is offline   Reply With Quote
Old 04-22-2021, 10:59 AM   #6
Cape Codder
Cape Codder's Avatar
13 - Check your Private Messages
Cape Codder is offline   Reply With Quote
Old 04-28-2021, 07:32 PM   #7
13
13's Avatar
Thank you for your help Joe
