09-22-2020, 01:51 PM | #1 |
T front spring
I need some help getting a front spring for the T. I would prefer something cheap, does anyone know of a front leaf spring that will fit the T that won't break the bank?
Sent from my SM-N960U using Tapatalk |
09-22-2020, 02:28 PM | #2 |
Re: T front spring
Keep an eye on eBay. New are really only a few hundred dollars and will last longer than you.
09-22-2020, 02:38 PM | #3 |
Re: T front spring
The ones I see are much more expensive, and as I am building a speedster, so I'm going low.
09-22-2020, 03:08 PM | #4 |
Re: T front spring
Try Snyder's Ford parts. I see one listed for about $250.
09-22-2020, 03:16 PM | #5 |
Re: T front spring
I'll look there, most of the ones I see are 300 and up. Thanks! By the way... What is the spring from eye to eye for a 18 to 25 front axle?
09-22-2020, 07:16 PM | #6 |
Re: T front spring
There are some reasons I would avoid fleabay for leaf spring, there on there for a reason CRAP. I would check MTFCA or your local craigslist, I do see in large parts sell offs. Again where your building a speedster and have measurement questions I would contact "T" springs and could probably build you a proper spring for your application. Good luck and let us know how you make out. Last edited by 39portlander; 09-22-2020 at 07:41 PM. |
09-22-2020, 07:24 PM | #7 | |
Re: T front spring
