10-06-2015, 12:20 PM | #1 |
removing 36 ford oil pan
Can the oil pan be removed with engine in the car?? Need to check out the plugs (pennys) on the bottom of block. Thanks
10-06-2015, 01:51 PM | #2 |
Re: removing 36 ford oil pan
I did remove the pan on my 1950 flathead, I had to remove bolts on engine mounts and jacked up the motor, I think I also unhooked the exhaust, that was a long time ago, can't remember all the details.
10-06-2015, 02:07 PM | #3 |
This will help you. You will have to lift up the front of the engine and rotate the crank so the oil pan will clear it for removal.
https://www.fordbarn.com/forum/showth...4637&showall=1 |
10-07-2015, 06:05 PM | #4 |
yup you can do it. but it is a bitch! it took me 4 hr to remove the pan in my 36 pickup
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
10-07-2015, 06:13 PM | #5 |
