Old 11-25-2019, 01:30 PM   #1
gtdohn
Default Bed wood adapter
DOes anyone know of a company that sells bed wood adapters for a 1948 Ford f1? They are the base used to raise the bed floor about an inch to accept a regular bed wood kit with the metal strips and all.
Classic Haulers used to sell them, but they are no longer in business.
Thank you.
gtdohn is offline   Reply With Quote
Old 11-25-2019, 03:30 PM   #2
TJ
TJ's Avatar
Default Re: Bed wood adapter
With the correct dimensions you could make them yourself. You already know that they need to be 1" thick. The width would be determined by the width of the metal cross brace.
Old 11-25-2019, 05:59 PM   #3
Scotty's 52 F3
Scotty's 52 F3's Avatar
Bruce Horkey's? Worth a try.
Scotty's 52 F3 is offline   Reply With Quote
Old 11-25-2019, 07:54 PM   #4
gtdohn
Where would one get true 1" wood?
Old 11-25-2019, 08:03 PM   #5
TJ
TJ's Avatar
You would probably have to custom cut it from larger pieces. If it's just used to shim the bed wood it doesn't need to made from any fancy wood. A building supply store or lumber supply would probably cut it for you.
Old 11-26-2019, 10:05 AM   #6
4tcoupe
Treated deck wood is usually 1" thick, but it will shrink and twist somewhat when it drys.
4tcoupe is offline   Reply With Quote
Old 11-26-2019, 01:27 PM   #7
gtdohn
I actually just found a bed wood adapter kit that used to be made for Classic Haulers. Now Mid Fifty sells them. So I bought one. problem solved.
