Old 03-04-2011, 02:11 PM   #41
Deuce Man
Deuce Man's Avatar
Default Re: A-V8 Roadster
Front spring leaves are pretty easy, I cant imagine doing that to a model A rear main leaf! Going to make up a fixture heat it up bright red twist the eye the other way. at least thats what I want to do. Any input on retempering.
Deuce Man is offline   Reply With Quote
Old 03-04-2011, 02:13 PM   #42
Deuce Man
Deuce Man's Avatar
Hey Chris you certainly captured the look! awesome car. Rich
Old 03-04-2011, 03:24 PM   #43
Chris
Chris's Avatar
Thanks, I am shooting for an early A-V8 car. Other then the steering box it is all pre 48. The steering box is an F-1 modified to fit the A frame like explained in the Tardell/Bishop book. The F-1 crossmember and pedals actually started in 1942 pickups.
Thee Inland Emperors
Chris is offline   Reply With Quote
Old 03-04-2011, 05:46 PM   #44
FL&WVMIKE
FL&WVMIKE's Avatar
DEUCE MAN ......................
A better way of reversing the eyes is to reverse the ARCH of the main leaf instead.
Trace the original arch, in chalk, on the floor and use a press to REVERSE the arch, to match your tracing. It works and does not affect the temper. Try it, you'll like it !
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 03-04-2011, 06:48 PM   #45
Deuce Man
Deuce Man's Avatar
Mike: I am talking about a model A rear spring pretty complex shape! Has anyone ever done this to one? Rich
Old 03-04-2011, 08:54 PM   #46
Joe AZ
Joe AZ's Avatar
I had a '33 spring redone the way Mike describes.....can't get anymore complex than that. You can also choose to "not" re-arch the spring as much as stock...lowering the car further.
Joe
Joe AZ is offline   Reply With Quote
Old 03-04-2011, 09:47 PM   #47
Deuce Man
Deuce Man's Avatar
Joe a 33 spring is a relatively simple shape compared to a model A. Look up a model a spring in one of the parts catalogs and you will understand what I am asking for.
Old 03-04-2011, 10:05 PM   #48
Fordors
I don't see any way that you will be able to correctly re-temper the ends of the main leaf; I think you will have a main leaf with "dead" ends and it will never work properly.
Regardless, fabricating a fixture and doing it yourself (time/labor) or finding a spring shop to re-roll the eyes for you ($) seems like a long way to go for the small amount of drop you will achieve. In post #15 Bassman's frame is Z'd; all Model A frames will require some fabrication and welding anyway so think how you want the car to sit and Z the frame accordingly.
Fordors is offline   Reply With Quote
Old 03-05-2011, 05:06 AM   #49
FlatheadTed
FlatheadTed's Avatar
I think the 1" you will gain could be had with lengthened the shackles ,but then you will need a stabiliser bar , By Removing three leaves then adding stiffer shocks could drop it down more, I dropped a 34 ,2 1/2 " by removing 4 leaves.
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 03-05-2011, 05:44 AM   #50
MN Stumpjumper
MN Stumpjumper's Avatar
I have reversed a rear spring useing the method and homemade jig from the HAMB. It is alot of work! I don't think I would do it again, You are right , that is alot of arch to turn around.
If you don't get it all the way to original shape it will be too long and hit bottom when installed. Some use model T springs with success.
MN Stumpjumper is offline   Reply With Quote
Old 03-05-2011, 10:41 AM   #51
flatheadA
I went to my local spring shop and they built a reverse spring for 35.00 dollars .I don't think you can do it any easier than that.
flatheadA is offline   Reply With Quote
Old 03-05-2011, 10:54 AM   #52
Chris
Chris's Avatar
You cannot run a longer shackle on an A because the spring sits right over the rear end...not behind it. Longer shackles would make the spring hit the axle.
Old 03-05-2011, 03:04 PM   #53
FlatheadTed
Yes Chris I didn't think of that .
Old 03-05-2011, 04:55 PM   #54
Bassman/NZ
Bassman/NZ's Avatar
What he said. I spoke to a spring specialist about this and he said rolling the eyes the opposite way is bad practice, they can crack.
Bassman/NZ is offline   Reply With Quote
Old 03-11-2011, 11:25 AM   #55
Deuce Man
Deuce Man's Avatar
[/IMG]
Took my stock Model A rear spring apart. Removed every other spring leaf then as recommended traced the main leaf on my workbench, not on the floor! Too old to bend over that much! With my arbor press I reversed the bend in the spring- not to bad a job. Next pre-loaded the spring to 750 lbs. which is what I guessed it will carry. Spring compressed 5 inches and grew 47" eye to eye. Does this sound right? My gut feeling is...I need that second (next to the main) leaf back. I have 5 now. What do you guys think?
Old 03-12-2011, 04:49 PM   #56
Deuce Man
Deuce Man's Avatar
Tacked in the rear spring hangers, after calculating how much the spring will spread under load. Seems to be in the ballpark. Dry fitted my center crossmember bottom. This will bolt to flange on original crossmember. There will be an extension going forward to locate the wishbone torque ball. Brake and clutch pedals next, with forward x-member legs. Then finish weld everything. Boy do I need practice welding!
Old 03-12-2011, 07:01 PM   #57
gerrald meacham
a bearing press will reverse the spring u have a good ideas 3 peaces of round stock and start bending i have done lots with a press copy it on the floor first nothing but sweat
gerrald meacham is offline   Reply With Quote
Old 03-12-2011, 08:34 PM   #58
flatjack9
flatjack9's Avatar
Hey Lee! Guess what I did while you guys were out for breakfast this morning? tacked in my front motor mounts, made up a little fan carrier, set my motor and transmission in place. Have to notch the center crossmember to get the back end of the motor, trans, up a little higher. Next thing to do is mock up my crossmember transmission mount/wishbone locator. Will do this in plywood first, then take template to Randy at Martin County Sheetmetal to have it cut and bent to shape. Besides 12 volt, my other modern concession is an RTS Ford four-speed overdrive. Going to cut off that ugly stick and graft on one of my old '39 sticks. Still fun up to this point.
Have this project at work - steal and hour (from myself) here and there. Work a little after work and Friday afternoons (we finish at 11:00 a.m. Fridays). If I had this at home waiting for me to do it evenings, it would still be a pile of rusty parts!
What sort of adapter did you use to mount the transmission? I use the same tranny, but I have only mounted it behind an 8BA block. Makes a great driving car. I have one in my 39 and grafted the 39 lever to the box. Shift lever is within 1/2" of the stock location.
flatjack9 is online now   Reply With Quote
Old 03-12-2011, 08:39 PM   #59
Fordors
It looks as though the main leaf is now longer after reversing it, or at least the eyes are further apart. The shackles have no load (weight) on them, yet they are closer to vertical then they are to horizontal. With the car completed and sitting on the ground with liquids and passengers the shackles will not work properly. Loaded I'd want to see the shackles near a 45* angle.
I save a lot of stuff and I've got measurements that put the spring eyes (spring on the bench) at 46" CC and the hangers on the rear end at 49" CC. I'm posting this not to be critical, but I think you should think this through, my only intent here is to help.
Old 03-12-2011, 10:52 PM   #60
Deuce Man
Deuce Man's Avatar
Thanks fordors as you saw in the previous picture I pre loaded my spring by lifting with my forklift. there is a load cell under it. I measured how much the spring spread Duplicated that with the bar clamps. Believe me those springs are stretching the bar clamps for all they are worth ! So actually they have the equivelant of 750 lbs on the spring If I let off on the clamps the spring eyes come together 6 inches and the spring grows in height by 5 inches. hope this makes sense to you this is what happens when a boat builder builds a car. Different path but we arrive at the same place.
