Old 12-25-2019, 09:32 AM   #1
PeterC
PeterC's Avatar
Default 1937 Ford Speedo?
Hi all - can you please confirm which speedo this is ... 1937 Ford? Deluxe? Standard? Other?
Thank you!
PeterC is offline   Reply With Quote
Old 12-25-2019, 09:38 AM   #2
dave collette
dave collette's Avatar
Default Re: 1937 Ford Speedo?
This is the same speedometer that came in my 1937 Deluxe business coupe. Hope that helps. Dave Collette
dave collette is offline   Reply With Quote
Old 12-25-2019, 09:46 AM   #3
V8COOPMAN
V8COOPMAN's Avatar
Thank you!
Good morning Peter, and Merry Christmas!
Your speedo is a '37 Standard. The picture below shows a '37 Deluxe, the difference being that the Deluxe has FOUR digits in the TRIP mileage window, whereas the Standard only has three digits. Dick D
Below is an actual Deluxe dash. Deluxe has the two vertical chrome strips, plus the BANJO wheel. Note FOUR digits!
The pic just below shows the actual dash in a '37 Standard. Note lack of vertical strips and THREE digit mileage window.
Click Links Below __
T5 W/TORQUE TUBE
Old 12-25-2019, 12:21 PM   #4
PeterC
PeterC's Avatar
DD - Wow - amazing that Ford would go through the expense to have 2 near identical speedo's with the only difference being 1 digit on the trip portion!
Thanks for all the details.
Old 12-26-2019, 12:01 PM   #5
Anton Voycheck
Anton Voycheck's Avatar
HI Dave.
Ford did not produce a "Business Coupe" in 1937.
Only three coupe models available for 1937:
Club Coupe, DeLuxe Coupe and Standard Coupe.
Anton Voycheck is offline   Reply With Quote
Old 12-29-2019, 05:04 PM   #6
TonyM
TonyM's Avatar
Originally Posted by Anton Voycheck View Post
HI Dave.
Correct, there are no 37, 38 or 39 Ford Business Coupes.
I know that there was 1940 Business Coupe (with jump seats), which is called by some -- but not Ford-- an "Opera Coupe."
What years did Ford have an actual Business Coupe?
TonyM is offline   Reply With Quote
Old 12-29-2019, 08:28 PM   #7
TJ
TJ's Avatar
I believe that there was a business coupe in '41. There was a coupe with jump seats along with the sedan coupe with the full back seat.
