Old 01-09-2020, 10:53 AM   #1
Bob NH
Bob NH's Avatar
Default Holly 94 carbs
I wonder just how important it is to have a real snug fit on throttle shaft in the cast iron base ? What would be acceptable and if the base is a bit worn, should you drill it out and make a bushing ?
Bob NH is offline   Reply With Quote
Old 01-09-2020, 12:03 PM   #2
tubman
tubman's Avatar
Default Re: Holly 94 carbs
Good fitting throttle shafts are always a plus. You can also get oversize throttle shafts.
Old 01-09-2020, 12:13 PM   #3
1948F-1Pickup
1948F-1Pickup's Avatar
Have not done this job on a 94. I did it on a rare Autolite 4100 and it fell into the category of "I ain't doing this again" because I ended up making the bushings, etc.
Maybe there are appropriately sized bushings available for the 94 on the market? Would make the job way easier.
1948F-1Pickup is offline   Reply With Quote
Old 01-09-2020, 12:24 PM   #4
FortyNiner
FortyNiner's Avatar
I sent mine to Charlie NY who magically transformed it. No learning curve required.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 01-09-2020, 12:44 PM   #5
rockfla
rockfla's Avatar
You will know IF its warn too much as one of the mixture screws will have NO effect on the idle of the car. Currently have that issue with one of mine!!!
Old 01-09-2020, 12:49 PM   #6
tubman
tubman's Avatar
I have used these several times with good results : https://www.speedwaymotors.com/Speed...haft,7124.html.
If you decide to go this way, it is wise to purchase a 9/32" reamer and not use a drill bit as suggested.
Old 01-09-2020, 12:58 PM   #7
supereal
supereal's Avatar
If your Holly 94 has evident wear at the throttle shaft, it may be time to invest in a replacement. Excellent new ones are available, and usually will enhance performance.
supereal is offline   Reply With Quote
Old 01-09-2020, 01:33 PM   #8
flatjack9
flatjack9's Avatar
Oversize shafts and the proper reamer are the ticket.
Old 01-09-2020, 01:43 PM   #9
Sid
Sid's Avatar
Many times you will find that most of the wear is in the shaft. It is softer than the base it goes through and wears. Sometimes just replacing the shaft will tighten things up. They also offer .005 oversize shafts. As suggested purchase a 9/32 reamer.
Sid is offline   Reply With Quote
Old 01-09-2020, 05:59 PM   #10
Black Fifty
Black Fifty's Avatar
I also sent my bases to Charlie. Well worth it!!!
Black Fifty is offline   Reply With Quote
