01-11-2016, 04:52 PM | #21 |
Re: Water Pump Woes
I found it necessary to jack the front axle up on a '37 engine (in a '36 frame) when removing the water pumps. I used jack stands to keep the front end up and wheels off the floor. This is in addition to a 2x6 under the pan and some padding between the pan and the wood block.
BTW, had no problems removing the botls on the pumps but when removing studs from my engine, I used Liquid Wrench and tapped the studs lightly every day with a hammer after applying the solvent. Did this for about a week with no problems removing the studs. Might be good for the water pump bolt. Also, didn't need to remove the radiator or other parts on my car. May be different for your model. Kerry |
01-11-2016, 09:08 PM | #22 |
Re: Water Pump Woes
Update: My woes have been cut in half. One of the bolts came out. The other is another story. Tomorrow I am going to try a mm socket. The correct socket turns on the bolt. I thank I will drive a mm socket on to it -and then try to get the bolt out.
RT |
01-11-2016, 09:28 PM | #23 |
Re: Water Pump Woes
I trick I learned from an old friend when you have a loose socket. Pound it on the bolt over a pop can or thin metal. Shims it up in a pinch and the impacts help loosen the bolt.
Funny thing is.............He originally did this when we were kids and he didn't have metric tools for his Honda. |
01-11-2016, 10:31 PM | #24 | |
Re: Water Pump Woes
01-12-2016, 12:27 AM | #25 |
Re: Water Pump Woes
Thanks everyone for the fine information. Hurrah for the S.E.C.
01-12-2016, 04:37 AM | #26 | |
Re: Water Pump Woes
I would not fret too much about using a GOOD GRADE stainless steel bolt for that inner WP bolt, along with anti/never seize on the threads. Now for those who may happen to have one of those high priced aluminum FH blocks and/or aluminum bodied water pumps , you will need to worry, or at least be concerned, about using stainless steel hardware.
01-12-2016, 12:18 PM | #27 |
Re: Water Pump Woes
I didn't intend to steal this thread but we used a flux core welder after trying a mig, neither was successful. This bolt has been heated, tapped with a hammer, soaked with PB Blaster and still won't move. I do have stainless bolts and anti seize compound to replace the old ones.
01-12-2016, 02:39 PM | #28 |
Re: Water Pump Woes
Not sure if it was mentioned yet but, let the bolt cool after welding the nut on.
Not trying to be a smart ass. I have seen guys start crankin on the nut while it was still red hot. Might get lucky that way but, usually just twists it off. |
01-12-2016, 03:02 PM | #29 |
Re: Water Pump Woes
I bought this little set of special sockets, I think I got them from crafman, I think about 6 sockets in the set, the socket has spiral theeth, drive the socket on over the stripped head of the bolt and it will bite right into head, I've used them quite often. very handy. Walt
01-12-2016, 05:48 PM | #30 |
Re: Water Pump Woes
Today was not as good of a day as yesterday. I tried different sockets and metric as well, but I had no good luck today. I think I will continue to be patient and flood the bolt with penetrating oil and also giving it a good "whack" every so often.
Walt, If you can come up with enough information on your sockets, I would be interested in trying to find a set. Stay tuned for the next chapter! Randy |
01-12-2016, 06:23 PM | #31 |
Re: Water Pump Woes
Drill the head off so you take the pump out.
Give it a soak and a wack with the hammer. Heat and patience is your friend |
01-12-2016, 07:14 PM | #32 |
Re: Water Pump Woes
Socket Extractors. The Blue is Irwin, Gray is Summit & Red is Craftsman.
01-13-2016, 02:19 PM | #33 |
Re: Water Pump Woes
I ordered a set of Irwin extractors last night and look forward to trying them. Thanks for all of the help. I will be sure to let everyone know what happens. Be on the alert!
Thanks everyone and JSeery for the pictures. Randy |
01-16-2016, 04:38 PM | #34 |
Re: Water Pump Woes
ALERT - ALERT - ALERT. YES, I finally got the bolt to come out with one of the extractors. It was a slow process, and I am really happy to have that behind me. I really appreciate everyones advice. I am so relieved that I don't have to remove the motor.
Thanks Randy |
01-16-2016, 05:02 PM | #35 |
Re: Water Pump Woes
Glad to hear your having success!
01-16-2016, 07:34 PM | #36 |
Re: Water Pump Woes
Now I,m wondering what is torque number for the water pumps? I really don,t want to think about twisting off a bolt. I plan to use stainless steel bolts. Thanks, Randy
01-16-2016, 07:37 PM | #37 |
Re: Water Pump Woes
Congradulations !!!.... You must have thought like winning..... Like the Patriots !!... Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
01-16-2016, 08:04 PM | #38 |
Re: Water Pump Woes
Yea, Sorry to see Berry lose. I sorta dread watching Peyton tomorrow night.
I really did celebrate my victory earlier today. Thanks Randy |
01-16-2016, 08:32 PM | #39 |
Re: Water Pump Woes
Keep in mind that stainless steel bolts are normally weaker than say a grade 8 bolt and much easier to break and then more difficult to remove. So take in easy on the torque on stainless. Might want to consider how long the bolts survived the first time around and often with very little thought to proper maintenance to the cooling system. Say it was last rebuilt even in the 60s, that's 50+ years ago.
01-16-2016, 08:37 PM | #40 |
Re: Water Pump Woes
General Bolt Torque chart based on bolt size. Notice the difference between Steel and Stainless. If your attempting to archive a specific clamping force it may be difficult without going to a larger size with a stainless bolt.
