Old 03-24-2020, 03:13 PM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default 59a Main bearings replacements
So now sourcing parts for 59A engine rebuild.
Main Bearings:
81A-63305-030 for 2.499" journal 39- 48
1BA-63305-030 for 2.499" journal. 49-53.
Are these bearings the same or are they different?
Thanks
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 03-24-2020, 03:16 PM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: 59a Main bearings replacements
Mainbearings must be for the type of block you use...older has a wider locking tab...-49 up has a smaller.
Old 03-24-2020, 03:21 PM   #3
Phil Gillespie
Appreciate your prompt assistance. Dont want to order from overseas and find out I've screwed up.
Thanks,
Phil NZ
Old 03-24-2020, 03:25 PM   #4
Mart
Mart's Avatar
Yeah you need the earlier type. the locking tab width is an easy indicator. The width of the web of the block at the rear main is different too. I learnt this the hard way when I assumed a French motor would use 8BA bearings. They dont. They use 59A type.
Old 03-24-2020, 03:28 PM   #5
flatheadmurre
You´re a bit to far away...Still have a few sets on the shelf.
Old 03-24-2020, 03:43 PM   #6
Phil Gillespie
Yes but sometimes the only source and you need to go with it.
Expect parts now ordered from overseas will be moving at a slower rate.
My crankshaft and block now in lock down for next 4 weeks.
Phil NZ
Old 03-24-2020, 03:46 PM   #7
swoopNZ
MEMBER EMERITUS
As far as the postal service is concerned there wouldn't be too much difference in shipping from either Sweden or the USA to NZ.
swoopNZ is offline   Reply With Quote
Old 03-24-2020, 03:59 PM   #8
Brian
Brian's Avatar
Probably cheaper from Sweden. I find USA postal charges to be the most expensive of anywhere in the world.
Old 03-24-2020, 04:00 PM   #9
flatheadmurre
Shipping still works atleast...i crated a flathead boatmotor going to south germany today.
A day slower or 2 is fine...just as long as it doesn´t stop completely...
Old 03-24-2020, 07:52 PM   #10
Talkwrench
Talkwrench's Avatar
Bra!
[if I got that correct]
Old 03-25-2020, 10:00 PM   #11
kiwitony
kiwitony's Avatar
Have you tried ajays and west coast ford?
kiwitony is offline   Reply With Quote
Old 03-26-2020, 03:30 PM   #12
Aarongriffey
The numbers that are the same identify the parts as main bearings.
The first number tells you what specific car or engine they fit.
Aarongriffey is offline   Reply With Quote
Old 03-26-2020, 06:11 PM   #13
Phil Gillespie
I'm pretty much sorted now with the bearings thanks to Flatheadmurre.
Much appreciated.
Phil NZ
Old 03-27-2020, 05:26 PM   #14
rotorwrench
rotorwrench's Avatar
The only engine you have to watch out for in those years in the Canadian sourced 69A. It has some different bearings associated with it. The 59A is no problem.
Old 04-04-2020, 05:47 PM   #15
Phil Gillespie
FlatheadMurre,
Am keen to sort out the purchase of bearings. Have sent you messages.
So will try here.
Thanks,
Phil NZ
