Old 06-16-2018, 07:31 PM   #1
michael a
michael a's Avatar
Default Tachometer for my model A
Can I use a 12-volt tack with a 6 to 12 volt Step Up regulator
Sent from my SM-J700T using Tapatalk
michael a is offline   Reply With Quote
Old 06-17-2018, 11:19 PM   #2
Pete
Pete's Avatar
Default Re: Tachometer for my model A
Yes on some. No on some. Try it.
Pete is online now   Reply With Quote
Old 06-18-2018, 12:16 AM   #3
Bill G
Bill G's Avatar
I recently bought and returned an electronic voltmeter from Harbor Freight that was supposed to be able to register engine RPM. Supposedly, either from clipping the probe to the coil or using the coil wire pick-up. It did not work. It just registered random numbers on the display. I took it back and claimed it was defective. They graciously exchanged it. The second one did the same thing, so I took it back and did not ask for another one.
I don't know why it would not work, but perhaps because it needed 12-volt power instead of 6-volt.
Old 06-18-2018, 01:03 AM   #4
Mike V. Florida
Mike V. Florida's Avatar
Too much noise from the unshielded ignition system for digital meters, especially inexpensive ones, to work. This is why analog meters with a needle are recommended for the Model A.
Old 06-18-2018, 08:50 AM   #5
katy
katy's Avatar
Ditto
Old 06-18-2018, 09:42 AM   #6
Flathead
Flathead's Avatar
I'm an analog guy in a digital world. So is the A.
Flathead is offline   Reply With Quote
Old 06-18-2018, 10:10 AM   #7
CHuDWah
CHuDWah's Avatar
Unless there's some reason you want 12 volt, this place sells 6 volt, + ground, 4 cyl tachs for $125
http://www.westach.com/
(Disclaimer: This post is only information, not recommendation. I have not done business with them so you're on your own there.)
CHuDWah is offline   Reply With Quote
Old 06-18-2018, 11:03 AM   #8
Davew
Davew's Avatar
I use a "tiny tach". Simple to hook up and works. I have a 6 volt system.
Davew is offline   Reply With Quote
Old 06-18-2018, 11:31 AM   #9
wmws
I use this model from Westech.com Works well.
Model: 2CT32-6V
Price: $124.65
Tachometer 3,500 RPM, 2" round, std pt ign, 2 imp/rev, 6 volt pos or neg grd ( 4 cyl )
wmws is offline   Reply With Quote
Old 06-18-2018, 12:47 PM   #10
Willie Krash
Willie Krash's Avatar
My ears are still working pretty well so I live in a tach free world.
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 06-18-2018, 01:02 PM   #11
Y-Blockhead
Y-Blockhead's Avatar
Model: 2CT32-6V
Price: $124.65
I think that should be Westach.com
Old 06-18-2018, 06:59 PM   #12
old31
Model: 2CT32-6V
Price: $124.65
I am using the same one and it works well.
old31 is offline   Reply With Quote
Old 06-18-2018, 07:46 PM   #13
Pete
Pete's Avatar
This is a pic of a Westach in a model A.
Old 06-18-2018, 10:21 PM   #14
Slowplane
Slowplane's Avatar
Red line 7200??
______________
Nothing Short of Right is Right
Slowplane is offline   Reply With Quote
Old 06-18-2018, 10:25 PM   #15
Pete
Pete's Avatar
Originally Posted by Slowplane View Post
Red line 7200??
Actually it was 6500. I never bothered to set the red pointer.
Old 06-19-2018, 08:06 AM   #16
wmws
Yes Y-Blockhead your right. Here is the web address.
[url]www.westach.com
The tac shown in post 13 is not the same one I have.
Old 06-19-2018, 09:03 AM   #17
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Bill Jones has a SMALL LED, rectangular tach, that sticks on his dash rail. It has its' OWN battery & I "think", a skinny wire, that just winds around the coil wire. You notice,I use a LOTS of QUOTATION MARKS, when I'm NOT SURE of stuff--LOL---Wouldn't EVER mean to MIS-LEAD someone.
Not "SURE" of the BRAND name???---MOSTLY, I just recommend stuff that has worked for me, PERSONALLY, in my SORID MECHANICAL BACKGROUND. "Sometimes" something I lurned while workin' on a GOGOMOBILE, "might" apply to a Model A.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 06-19-2018, 03:26 PM   #18
Y-Blockhead
Bill, you ever see the videos on this Gogomobile with a 'Radial' engine. pretty crazy
https://youtu.be/f2V7B7-gdRA
https://youtu.be/Xk8d-bMhViM
https://youtu.be/luvkcP0mkgA
Sorry for the detour...
Old 06-19-2018, 06:21 PM   #19
Tom Endy
Tom Endy's Avatar
The Westech 6-volt model 2CT32-6V looks interesting. Could some of you who have installed this device post some descriptions on how you mounted it and hooked it up eclectically in a Model A.
Tom Endy
Old 06-19-2018, 07:00 PM   #20
31 Woody
31 Woody's Avatar
Not trying to be critical or funny, but why would I want a tach in a Model A? I have one in my Mustang Cobra, which does redline at 7,000...been there many times in fact. But the Model A just does not make sense to push and the actual RPMs do not seem important. Is this a curiousity being satisfied?
Experience is a cruel teacher. It gives the exam first, then the lesson.
31 Woody is offline   Reply With Quote
