Old 06-26-2023, 12:01 PM   #1
CSPIDY
CSPIDY's Avatar
Default Polarizing 48 F1
I’m working on a 1948 F1 Pickup with a V8
Someone had previously switched the battery polarity to neg grid.
I have switched it back to pos grd, verified the coil is pos grd.
when it runs the amp meter moves to discharge
I would like to polarize the generator but not sure what procedure to follow
appears there are two types of generator systems
the wiring is all original, ick
Dave
CSPIDY is offline   Reply With Quote
Old 06-26-2023, 12:13 PM   #2
flathead48
Default Re: Polarizing 48 F1
If you have a B circuit, regular will show posts in this order B F A , UNHOOK field wire on reg & touch to battery post on reg, quickly
If A circuit, regular B A F USE A JUMPER from A to B
flathead48 is offline   Reply With Quote
Old 06-26-2023, 01:21 PM   #3
CSPIDY
CSPIDY's Avatar
That’s the question
which type system do I have
File Type: jpg 24C71249-B8B4-436C-823E-90EE11A64F01.jpg (66.6 KB, 22 views)
File Type: jpg 46EF5012-060C-4C0E-AE28-83279ADF9BCF.jpg (66.3 KB, 25 views)
Old 06-26-2023, 01:59 PM   #4
CSPIDY
CSPIDY's Avatar
Found an old thread where rotorwrench explained it
Pulled the field wire from the generator
touched the field with battery power
Generator works as advertised
Thank you
Old 07-01-2023, 08:37 AM   #5
Ramblin Reck
Ramblin Reck's Avatar
Thank you
CSPIDY
Please share rotowrench's post explaining the difference as I urgently need this information! Thanks
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems!" ROGER, WILCO, OUT!
Ramblin Reck is offline   Reply With Quote
