04-30-2020, 01:28 PM | #1 |
Is this an air cleaner or a...?
Ladies and Gents,
Is this an air cleaner or some sort of heater apparatus? It came along with my 36 Fordor. Thanks, T Untitled by Mike Terranova, on Flickr Untitled by Mike Terranova, on Flickr |
04-30-2020, 01:40 PM | #2 |
Re: Is this an air cleaner or a...?
It's most of a heavy duty oil bath air filter. It appears the bottom is absent.
And it is likely that it has been modified a bit. I believe, but am not 100% certain, this is pre 1937. I'm confident there are those here on the Barn that can dictate correct applicable years.
04-30-2020, 02:10 PM | #3 | |
04-30-2020, 02:29 PM | #4 |
Rockfla, Thanks for adding to this discussion.
I believe the design was changed for '37 forward to what I have depicted in the attached photograph..
04-30-2020, 03:11 PM | #5 |
I believe this is what a complete assembly looks like. I got this when I was helping the widow of a friend of a friend dispose of some of her deceased husbands parts stash. He was into 32-34 pickups but when I asked around I was told that it wasn't 32-34. So I'm not sure what its from, just know I still have it.
04-30-2020, 03:34 PM | #6 | |
IF memory serves me correct DAVIDG's 33 4cyl coupe he is restoring has the HD Air flilter so it just wasn't strictly a V8 "thing". |
04-30-2020, 04:56 PM | #7 |
The one i got has the flat top on the air duct. Its missing the mounting bracket. I think i took it off a truck but sorta recall it was a 6 cyl.
When did the truck carburetor change the top of the air horn to the bevel style? |
