06-05-2019, 04:27 PM | #1 |
Amount of grease for 46 Driveline
I’m not sure what the PO did as far as greasing the driveline, or how much is already in the u-joint or driveshaft bearing, so the questions are:
Can the u-joint/clamshell be overgreased? If too much grease, will it get into the speedo drive/able? Can the driveshaft bearing be over greased? Again, I don’t know how much grease is already in these areas. |
