04-05-2021, 08:01 PM | #41 | |
Re: 1cm
Are you maybe talking about a trans with a shifter like this? DD |
04-05-2021, 08:11 PM | #42 | |
Re: 1cm
And Nitrous, don't forget the Nitrous.
"Sometimes he would accuse chestnuts of being lazy, the sort of general malaise that only the genius possess and the insane lament." |
04-06-2021, 09:34 AM | #43 |
Re: 1cm
Those Lincoln side shift set ups were definitely different.
04-06-2021, 10:24 AM | #44 |
Re: 1cm
Ha! You wanna see "different"? You ALSO wanna see "side shift set-up"? Compare the bolt pattern on the SHIFTER cover on BOTH boxes....they are both the same Lincoln Zep CASE! Does everyone realize what the BOTTOM transmission was used in? DD |
04-06-2021, 12:57 PM | #45 | |
Re: 1cm
Given the clutch arm on the right side of the trans I'd guess English or Aussie but of course that is just a guess.
04-06-2021, 09:03 PM | #46 |
Re: 1cm
04-06-2021, 11:20 PM | #47 |
Re: 1cm
Simply put, it's a RHD (Right Hand Drive) trans used 1940-'48, as in the second picture below! It's interesting to note that the INSPECTION Cover and the 'Serial #' pad are not lined-up straight on these. DD |
04-07-2021, 06:09 AM | #48 |
Re: 1cm
This is a valve from the mercury block, I guess the C stands for Canadian.
04-07-2021, 07:44 AM | #49 |
Re: 1cm
If Ford of Canada changed to rotator type valves than that is likely an example of the Canadian part. They used the C in the prefix on a lot of their parts.
04-07-2021, 11:37 AM | #50 |
Re: 1cm
That's a '52 hood on the truck, the hood trim also appears to be '52. Can you post the serial number?
'52 F-1, EAB flathead |
04-07-2021, 07:01 PM | #51 |
Re: 1cm
