Old 10-06-2019, 11:53 PM   #21
Jwawhite
Jwawhite's Avatar
Default Re: vibration in my car
Raise one right front wheel off the ground, grab wheel by 9 and 3 o'clock and see if there is a lot of movement. Take a look at the Idler Arm to determine if the rubber bushings are kaput. Tell me what you find out.
Jwawhite is offline   Reply With Quote
Old 10-07-2019, 03:56 AM   #22
KULTULZ
KULTULZ's Avatar
Post Re: vibration in my car
The LF tire rolled smooth, hand on fender no issues. When the RF wheel was rotated, it is obvious there is an issue, the RF fender was hopping.
The Operators opinion was the wheel is bent. I saw the lower inside wall of the tire with a wobble. I ALSO THOUGHT THE WHEEL WAS BENT.
Are you sure the tire itself is not bad? Switch front tires and see if vibrations moves to other side.
All bushings (idler arm - control arm - PS linkage) must be good. For example if outer tie rods are bad, you will get a front end vibration usually around forty to fifty miles and hour.
If vibration is felt in steering wheel, it is usually front related. Vibration in seat of pants, drive-line vibration.
Much less, with a loose front end, there is no way the front end can be aligned.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 10-07-2019, 11:35 AM   #23
dmsfrr
dmsfrr's Avatar
Originally Posted by Jwawhite View Post
... I've seen each wheel on the car rotated while off the ground.
The front wheels were rotated up to 60 + MPH, one at a time by a machine with a roller, electrical motor. The LF tire rolled smooth, hand on fender no issues. When the RF wheel was rotated, it is obvious there is an issue, the RF fender was hopping.
I saw the lower inside wall of the tire with a wobble- ...
... The wheel was removed and placed on a Balancer Machine and spun, the rim is not bent! Just what is happening, besides time and money?
Swapping the RF tire & wheel to the LF will likely confirm that the tire itself is defective.
If the wheel spins true but the tire & wheel together wobble when they're off of the car, the tire is the culprit.
Old 10-07-2019, 03:01 PM   #24
Jwawhite
Jwawhite's Avatar
O. M. G.
What does this printed word read on my RF Drum? The shaking side?
Old 10-07-2019, 05:50 PM   #25
KULTULZ
KULTULZ's Avatar
Originally Posted by jwawhite View Post
o. M. G.
What does this printed word read on my rf drum? The shaking side?
BENT!
If the drum is actually bent and will not sit on the hub correctly, that may be the cause of what you saw wobbling. It pushed the wheel out of line.
- WHY IS IT ... -
Old 10-07-2019, 06:14 PM   #26
dmsfrr
dmsfrr's Avatar
"Bent" is what it looks like from over here too.
Old 10-07-2019, 07:08 PM   #27
50fordcoupeman
50fordcoupeman's Avatar
Yep looks like paint stick wrecking yards used.
50fordcoupeman is offline   Reply With Quote
Old 10-11-2019, 11:47 AM   #28
bobss396
bobss396's Avatar
Swap the tires around, back to front and see how it rides. Where do you feel the vibration? Steering wheel, brake pedal??
bobss396 is offline   Reply With Quote
Old 10-11-2019, 02:24 PM   #29
56yblock
56yblock's Avatar
hat's what i've done,and it's the same thing....
56yblock is offline   Reply With Quote
Old 10-11-2019, 03:44 PM   #30
KULTULZ
KULTULZ's Avatar
Question Re: vibration in my car
Originally Posted by 56yblock View Post
That's what i've done,and it's the same thing....
Feel in steering wheel or in the driver's seat?
If at speed, if you put it into neutral, does the vibration subside? Does it do it under power and/or coast?
- WHY IS IT ... -
Old 10-11-2019, 05:21 PM   #31
Jwawhite
Jwawhite's Avatar
Open the hood engine operating in park, position the throttle at cruise speed, does engine shake?
Old 10-12-2019, 05:54 AM   #32
56yblock
56yblock's Avatar
both...
Old 10-12-2019, 07:00 PM   #33
Rusty Junk
I had a Ford with a driveshaft that was made up of two parts with rubber in the center, anyhow the shaft had come out of faze ever so slightly causing the vibration. My fix was to have a new one peice shaft made and vibration was gone.
Rusty Junk is offline   Reply With Quote
