Old 06-03-2019, 02:47 AM   #1
my4dv8
Default 48 to 52 f1 steering box
Hi guys. Does anyone have knowledge of a source of rebuild parts for a RHD F1 steering box 48 to 52 pickup?
my4dv8 is offline   Reply With Quote
Old 06-03-2019, 03:22 AM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: 48 to 52 f1 steering box
If i remember right the car wormgear and rollergear fits the RHD pickup...
So should be a common part...
Old 06-03-2019, 01:04 PM   #3
NealinCA
NealinCA's Avatar
Most early Ford parts suppliers have the RHD worms. All other rebuild parts are the same as LHD, granted your sector shaft is rebuildable. And the comment above is correct, in that 37-48 Ford car RHD internals can be swapped into your RHD F1 box if needed.
NealinCA is offline   Reply With Quote
Old 06-03-2019, 04:55 PM   #4
my4dv8
Ok had a look in my stash and it does appear 37 40 type passenger and 48 52 F1 share the same replaceable components . Unless i am mistaken ,again. The top worm and sector are F1 and the lower one are passenger. Now to find a supplier of a RHD kit.
File Type: jpg 6BD445B5-131C-4AD6-AB4B-A3E5F541107F.jpg (53.8 KB, 21 views)
Old 06-03-2019, 06:58 PM   #5
NealinCA
NealinCA's Avatar
See links below for the RHD worm:
https://www.macsautoparts.com/ford_t...f2-and-f3.html
https://cgfordparts.com/ufolder/ford...ber=78-3524-RH
All other rebuild parts are the same as LHD.
Old 06-03-2019, 11:54 PM   #6
flatheadmurre
Isnīt it like that the LHD car parts are the same as RHD pickup...
Same as that the early RHD parts is just another years LHD parts.
Depending on if the sectorshaft goes CW or CCW.
And thatīs the reason Macs and other vendors stock the RHD parts...itīs just another model LHD part...check the ford part numbers should give you a clue...
Old 06-04-2019, 10:46 AM   #7
NealinCA
NealinCA's Avatar
No, that is not the case here. 37-48 passenger car steering box internals are the same as 48-52 pickup internals when they are both either LHD or RHD.
LHD sectors have the roller canted to the right, RHD sectors have the roller canted to the left.
Old 06-04-2019, 02:16 PM   #8
my4dv8
they are different as Neal says.
1937-1948 Steering Box Rebuild Kit (Right Hand Drive)
[78-3503-RHDKIT
[78-3503-RBLDKIT]
