Old 02-20-2020, 12:33 PM   #1
jjlamb
Default Serpentine System for Flatheads
I like the old school simplicity of these flatheads, but I like the constant tension and lack of slippage on modern serpentine systems. Unfortunately, the serpentine sytem made by March Performance is out of my price range at $2100. I also don't like the billet look of it. It's too modern compared to the flathead.
Has anybody put together their own serpentine system that is more "old school", and hopefully cheaper? What are your thoughts?
jjlamb is offline   Reply With Quote
Old 02-20-2020, 12:56 PM   #2
Jack E/NJ
Jack E/NJ's Avatar
Default Re: Serpentine System for Flatheads
Rollerskate/skateboard wheels. Jack E/NJ
Old 02-20-2020, 01:03 PM   #3
tubman
tubman's Avatar
That's cool, in a billet sort of way, and I like the symmetry. But, like you said, it is a totally inappropriate look.
I don't know if you could make a serpentine setup look good on a flathead. the dual water pumps make it too complicated right from the start.
Old 02-20-2020, 01:17 PM   #4
19Fordy
19Fordy's Avatar
Pulleys painted painted same as engine color might improve the look but,
it would still look out of place.
19Fordy is online now   Reply With Quote
Old 02-20-2020, 01:21 PM   #5
STEVE O
STEVE O's Avatar
Very high belt tension needed to run the serpentine belt drive which loads all bearings much higher than a v belt which requires very little.
STEVE O is offline   Reply With Quote
Old 02-20-2020, 01:31 PM   #6
Jack E/NJ
Jack E/NJ's Avatar
Skateboard wheel tensioner on my 21 studder. You need 'em to prevent alternator belt slippage/squeal when it's delivering a lot of amps to the battery and accessories. I use them on my 60s era OT car. Jack E/NJ
Old 02-20-2020, 01:43 PM   #7
jjlamb
The skateboard wheel is an interesting idea. The serpentine systems do put more bearing load on the accessories, but not a lot more bearing load is required because the serpentine systems generally have more degrees of "wrap" on the pulleys. Maybe a serpentine system made out of aluminum plate would work, and the do some engine turning on it to give it some old-school bling.
Old 02-20-2020, 01:51 PM   #8
ford38v8
ford38v8's Avatar
These are interesting ideas you have. Save them to look back on with giggles several years from now.
Seriously, I'm not putting you down, every newbie starts off with ideas that he later thinks differently about.
Alan
Old 02-20-2020, 02:05 PM   #9
Krylon32
I used to do a serpentine system but it was for one of my 409 to FH water pump kits.
Krylon32 is offline   Reply With Quote
Old 02-20-2020, 02:11 PM   #10
Zeke3
Zeke3's Avatar
The March website says they are using the power steering pump to tension the system. I think that is the pulley in the middle where the fan hub is usually located. One of those idlers should probably be an automatic tensioner, but it wouldn't look as pretty.
Alignment is much more critical with a poly vee belt drive than a standard v-belt.
Zeke3 is offline   Reply With Quote
Old 02-20-2020, 02:42 PM   #11
Jack E/NJ
Jack E/NJ's Avatar
jjlamb>>>not a lot more bearing load is required because the serpentine systems generally have more degrees of "wrap" on the pulleys.>>>>
Agreed. Getting more degrees of wrap on the pulleys is the main advantage of idlers. Less tension is required to stop slippage on the stock flathead setup. Jack E/NJ
Old 02-20-2020, 02:50 PM   #12
Tim Ayers
I find it interesting that they've got A/C and an alternator on what looks like a relatively stock motor
Old 02-20-2020, 03:00 PM   #13
jjlamb
Here's a link to the installation manual for the March system.
https://marchperformance.com/media/w...nstrctions.pdf
Old 02-20-2020, 03:55 PM   #14
Krylon32
Joe at Roadrunner Engineering did some things with serpentine belts.
Old 02-20-2020, 04:04 PM   #15
jjlamb
I see he uses them as part of his supercharger kits. I wish there were more pictures of his setup.
Old 02-20-2020, 04:31 PM   #16
RalphM
RalphM's Avatar
I can’t remember the name of the maker of the blower he installed but when a friend put it on his flathead it came with a serpentine belt kit.
I have the brochure at home.
RalphM is offline   Reply With Quote
Old 02-20-2020, 05:00 PM   #17
jjlamb
I just did some more googling. Here's a couple pictures:
Old 02-21-2020, 06:38 AM   #18
Tim Ayers
Roadrunner Enginering?
Old 02-21-2020, 02:56 PM   #19
old school rodder
Check out Tom Roberts Design in CA. he sells a serpentine system, I just put one on my 59ab. I like it so much, gonna do my other one. Very reasonably priced, good parts.
old school rodder is offline   Reply With Quote
Old 02-21-2020, 03:19 PM   #20
JSeery
JSeery's Avatar
Didn't find any good photos, but this is the Tom Roberts setup. I'm not a billet fan myself.
