09-27-2019, 10:20 PM | #1 |
Radiator shops in Houston Texas
Anyone have recommendations for good radiator shops in Houston Texas to rebuilt original 1948 Ford Tudor Sedan radiator? For context of why I am asking, please see below.
My original 1948 Ford Tudor Sedan radiator probably needs to be rebuilt. The motor was rebuilt a few years ago and I have been running the motor off and on while I was finishing up restoring the car. Now since it’s done, I’ve started running it more and for longer periods and under load on the road. I finally got a aftermarket gauge hooked up that shows temps for each head to just check exact numbers. While it was idling in the garage, one side got up to 180 dog while the other head started to push 205/210. I did notice that the level in the radiator was down so I guess that could be it. I added more 50/50 AF but did not get a chance to rerun to check everything out. I do not have any leaks and no water in the oil so I believe it’s either 1) bad radiator or 2) bad water pump. Any way to check if water pump is bad or confirm radiator is clogged up? |
09-28-2019, 12:15 AM | #2 |
Re: Radiator shops in Houston Texas
I worked at Longpoint Radiator as a teenager, don’t know if they are still around, but worth a look.
Off longpoint and Bingle rd. Used to be a real radiator shop. |
09-28-2019, 11:21 AM | #3 |
I had the radiator in my '37 Ford cleaned and repaired recently by Freitag Radiator in Hempstead. He did a good job on it, the price was reasonable and it only took 3 days. This is a one-man shop and he and his father have been doing this for many decades. Google for address and phone number.
09-28-2019, 12:51 PM | #4 |
Usually replacement is a wiser investment than repairing. Look to pay about $600 for top quality brass core units. Original style types are a bit more, about $850. Reference C&G catalog, pages 100-101.
09-28-2019, 02:01 PM | #5 |
Do you have thermostats?
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
09-28-2019, 02:13 PM | #6 |
09-28-2019, 06:20 PM | #7 |
you may find it will run a little cooler with water instead of antifreeze. in houston, i would not think freezing is much of an issue. perhaps even a lighter mix than50/50 would help
09-28-2019, 08:24 PM | #8 |
Thanks everyone. Doesn’t look like I need a new radiator. Drained the radiator and put in a diluted 50/50 mix. Also got it out on the road and it didn’t go above 200 degrees on either head. The diluted mix and improved airflow did the trick.
I will have to replace the original mechanical fan as the one on the car gave out right as I was pulling in to my driveway. Unknown to me, the oil in the fan hub had drained and given the extended drive today, it decided it had enough. Going to order a oil-less new unit from Macs next week. |
09-29-2019, 10:22 AM | #9 |
I find it amazing that you are able to drive a 48 Ford in all that crazy traffic! I was there for a couple months in 2017/18 and found it difficult at best, in a modern car.
Way different than when I was a kid in the 70’s, Even back then I stayed off the freeways in my old 55 Ford. |
09-29-2019, 02:08 PM | #10 |
RalphM, I stay away from the freeways or highly congested areas as well. Luckily I know the back roads to get where I am going haha
09-29-2019, 02:51 PM | #11 | |
Glad to hear that trying the above worked-out for ya. Look at all the beer money (and hard work) you saved by trying the obvious first. Plus, you never would have known that you DIDN'T really have a problem. What area of Houston do you live in? DD |
09-29-2019, 06:02 PM | #12 |
Also, new engines normally run a little hotter that it will with some miles on it.
09-29-2019, 08:43 PM | #13 |
V8Coopman, you are right. I can use that extra money for the next project car now. I live in the Clear Lake Area.
JSeery, thanks for the additional info. It startled me a bit to see the temps. |
09-30-2019, 04:16 AM | #14 |
One other thing....have you retorqued the heads?
09-30-2019, 05:30 AM | #15 |
Brian, I have not. Given it’s being driven more, should I ? And if so, what should I torque them to?
09-30-2019, 06:50 PM | #16 |
Yes, you should/must retorque after several heat/cool cycles until the gasket has fully compressed, ie, the heads hold torque. Torque should be to specs for the heads you're using.
You'll find the heads pull down with this retorquing, this will improve the sealing also possibly improve your observed operating temps through not having compression leaking into coolant.
10-02-2019, 07:34 AM | #17 |
Thank you, Brian. I have stock heads so I’ll look for the torque specs
