05-19-2019, 03:20 PM | #1 |
can't access passenger rear exhaust manifold bolt
Greetings, on my 57 Fairlane Sunliner I can't get access to the exhaust manifold bolt, passenger side, nearest the firewall. It's behind a leg of the manifold, too close to allow socket. And too close to the firewall/fender well to allow a box or open-end wrench to be turned. Really don't want to pull the engine (giving room to use a box wrench) if I can possibly help it.
The bolt's not frozen, in fact it's slightly loose -- I just can't get a wrench on it to tighten or remove it. On a 1 - 10 scale of mechanics, I'm about a 3.5 so what may be an obvious solution is eluding me. Any suggestions would be appreciated. Thanks! |
05-19-2019, 03:33 PM | #2 |
Re: can't access passenger rear exhaust manifold bolt
Believe there is a section devoted to the post flathead cars, they might be more knowledgable on your question.
05-19-2019, 11:11 PM | #3 |
Ah, thanks! I mistakenly went with the early models - noob mistake I guess. I'll post in the correct forum.
05-20-2019, 03:03 PM | #4 |
Hook |
