12-20-2020, 11:34 AM | #21 |
Re: Noisy Hood Hooks
Hood latch handle bumpers. They go over latch handle to keep it away from hood.
I know C. W. Moss has them. In the past I have also purchased from Mac’s. If you install all the required bumpers and the roping between body/grill and hood, should be quite. |
12-20-2020, 05:13 PM | #22 |
12-20-2020, 05:20 PM | #23 |
The bumpers are mounted on the hood and would have come on the car original. Link posted in my post on page 1.
The latch tip protectors (caps) are an after market item; https://www.snydersantiqueauto.com/P...earchByKeyword Also don't forget the pads under the latches; https://www.snydersantiqueauto.com/P...S-2-HOLE-BLACK
12-21-2020, 02:05 PM | #24 |
Thank you for your comments but I did have the plastic tips on the hook. I think these squeaks are coming from inside the barrel of the hood hooks, the spring and internal shaft. You can pull on the hood hook and hear nasty sounds coming from the parts rubbing inside. As I mentioned before I dripped 600W down inside the hook but it doesn't fix the problem for very long. Ford must have had complaints about these because the hood hooks for 1932 were much nicer. Ed
12-21-2020, 09:44 PM | #25 | |
Noisy Hood Hooks
Are your hooks rusty inside? Sent from my iPhone using Tapatalk |
12-23-2020, 12:21 PM | #26 |
