Old 06-28-2015, 12:32 PM   #1
Mart
Mart's Avatar
Default 94 carb question.
I can pull the carb bodies off my roadster and leave the throttle bodies in place.
When I pull the carb bodies, I can see some wetness in the chambers that the heads of the power valves sit in. I can also see some wetness on the heads of the power valves.
Is this normal? I am thinking the heads of the valves and the chambers should be dry. Does dampness indicate a leaking diaphragm or a incorrectly seated gasket?
I have the bodies filled with fuel sitting over a spare pair of throttle bodies. they are bone dry so I will leave them for a while and check for any leaks. Without the powerful vacuum generated by the engine, though, I don't know how well this will work.
So, those chambers, then, should they be dry?
I borrowed this image off the internet, the chamber is the uppermost round area in this pic.
Mart.
Old 06-28-2015, 01:07 PM   #2
Ross F-1
Ross F-1's Avatar
Default Re: 94 carb question.
Should be dry.
Try pushing down on the button on the top of the PV shaft to flex the diaphragm to see if that starts it leaking.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 06-28-2015, 04:12 PM   #3
scooder
As Ross said Mart, should be dry, try flexin the valve aswell.
Martin.
scooder is offline   Reply With Quote
