06-12-2019, 07:08 PM | #1 |
LED head lights
I just installed a new wiring hardness in my 31 Cabriolet and at the same time I installed LED head lights. Last night I drove the car for about 40 miles in the dark and the LED lights performed very well. The high beams seem to work very well and light up the road better directly in front of the car. These install directly into the original sockets and this makes it very easy. My car is 12 volt negative ground if this makes any difference, so I order the 12 volt LEDs. I just thought I would pass on this information.
06-12-2019, 09:43 PM | #2 |
Re: LED head lights
So what brand are they?
06-13-2019, 05:30 AM | #3 |
Re: LED head lights
Where did you purchase the bulbs................Bob
06-13-2019, 12:14 PM | #4 |
Re: LED head lights
I bought them from Brattons.
06-13-2019, 05:42 PM | #5 |
Re: LED head lights
06-13-2019, 05:56 PM | #6 |
Re: LED head lights
https://www.brattons.com/led-headlight-bulb.html If you buy/try them, please post a review. I have the logolites, but am on lookout for something that focuses better. |
06-13-2019, 06:39 PM | #7 | |
Re: LED head lights
I allready have led parking lites -- just ordered the head lamps. PM your email and I'll send pictures of what the parking lites look like. I've never figured out how to post pictures. The parking lites are really bright, I run them more to mark my presentsThans |
06-13-2019, 06:55 PM | #8 |
Re: LED head lights
the LED head light bulbs are part #17994 and they cost $29.95 each. I replaced the reflectors, sockets, connectors, gaskets, focus spring and screw - everything for the head lights and it gets a little expensive but I am glad to have everything installed as it should be for the first time since I have owned the model A. The headlight terminal ends ( 3 on each side) are a challenge to solder in and keep all wires exactly the same length.
06-13-2019, 11:13 PM | #9 | |
Re: LED head lights
Am only interested in the headlights, have converted to all LED. But like I said, keeping my eyes open for reports of focusable headlights, the logos do not focus well. |
06-14-2019, 08:14 AM | #10 |
Re: LED head lights
My guess is they are LogoLites. Just about the same price and the other vendors are selling them too.
06-14-2019, 10:37 AM | #11 |
Re: LED head lights
Has anyone found a LED parking bulb that works with 2 bumps on the bulb?
All the leds I tried are too long and hit the glass. I use the lamps for both parking and directionals. |
06-14-2019, 01:04 PM | #12 | |
Re: LED head lights
I finally found mine at: http://www.dynamoregulatorconversion...bulbs-shop.php Part # CE1A, 12v 21/5w BAY 15D Amber White - Neg Earth (They do have the equivalent in 6 volt positive as well)
Alaskan A's Antique Auto Mushers of Alaska Model A Ford Club of America Model A Restorers Club Antique Automobile Club of America Mullins Owner's Club Last edited by CarlG; 06-14-2019 at 02:19 PM. Reason: Add info |
06-16-2019, 04:12 AM | #13 | |
Re: LED head lights
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me. |
06-15-2019, 07:20 AM | #14 | |
Re: LED head lights
https://www.ledlight.com/g18-s25-6-2...-polarity.aspx |
06-15-2019, 09:58 AM | #15 | ||
Re: LED head lights
incandescent (2-6 CP) The 12 is a bit of a squeeze, but will fit the cowl lamp. Quote:
The ones from dynamo old31 mentions seem to be the best, but in another thread Karl said they wouldn't pass local inspection in NZ. |
06-14-2019, 10:55 AM | #16 |
Re: LED head lights
There is no question that these are NOT ready for model a's at all, They are NOT focusable and cannot be aimed correctly, There is no high beam it is only a bright beam with more filaments, there have been extensive reviews on these and you can see them on the ford vintage. They only spread the light same as an LED in your backyard...it only lightens the area and not the direction you drive....I have done an extensive experiment on these IMHO..
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
06-14-2019, 04:12 PM | #17 |
Re: LED head lights
Just purchased a set of LED's headlights and new harness set from Snyder's.
Just purchased a set of new reflectors from Bratton's. The 6 volt Halogen set I have been using for the last 15 years has melted the bulb plug resulting in arcing of the contacts about 4 times over this period. This spring, both left and right are in need of replacement again on my Phaeton. I thought I would try the LED's...If they don't work, Ill buy another set of plugs for the Halogen bulbs. The only plugs available now are made from a "plastic" and do not handle the heat produced from the 6 volt Halogen bulbs. I used to purchase the "Bakelite" like plugs and they would last twice as long. Cannot find them anymore at NAPA. Good Day! Last edited by Dave in MN; 06-14-2019 at 04:39 PM. |
06-16-2019, 04:01 AM | #18 | |
Re: LED head lights
06-14-2019, 11:34 AM | #19 |
Re: LED head lights
It can be made to work, I have idea, but not much incentive, it will be more $$ than most will be willing to spend, but my now headlight project is playing with HID bulbs, they will focus with original reflector
06-14-2019, 04:52 PM | #20 |
Re: LED head lights
I use the direct fit halogens with original sockets---- I did rewire with heavier gauge aircraft wire, 45 years ago, no socket melting in 15 years of halogen use
I suspect you have H4 bulbs , they can be higher amperage, ---- I will look in some benz headlights to see what they used for sockets with h4 bulbs |
