Old 12-04-2014, 05:54 PM   #1
Bookaray
Default Champion W18 spark plug
I just installed Champion W18 plugs in my '28 Coupe. Should I set the spark gap at .025 as recommended by Champion, or .035 like the W16Y plugs I had been using? It is running well, but really hard to start.
Bookaray is offline   Reply With Quote
Old 12-04-2014, 06:15 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Champion W18 spark plug
It really doesn't matter. The closer the gap the less likely there is of a high [? in a Model A] speed misfire. Wider the idle may be a little smoother. But, it'll probably be hard to notice either.
Old 12-04-2014, 06:29 PM   #3
Bookaray
Thanks. Would having a closer spark gap make it harder to start?
Old 12-04-2014, 06:47 PM   #4
Patrick L.
Patrick L.'s Avatar
Nope. I run mine in the A [and most others] closer.
Old 12-04-2014, 06:49 PM   #5
Bookaray
Thanks!
Old 12-04-2014, 06:59 PM   #6
Purdy Swoft
Purdy Swoft's Avatar
Yes a too narrow gap will hinder sarting . I run mine with a gap of .035 . I wouldn't run any spark plug in any of my model A's with a gap less than .035 unless I had a coil going out and I had to close the gap so that a weak coil could jump the gap to get home. You may have a weak coil.
Old 12-04-2014, 07:14 PM   #7
Bookaray
Thanks!
Old 12-04-2014, 07:20 PM   #8
Mitch//pa
a narrower gap can create a weaker spark causing an incomplete burn. your better off at .035 for a stronger spark and a complete burn. to wide of a gap can cause a high speed misfire
Old 12-04-2014, 10:49 PM   #9
Bookaray
Thanks!
