Old 09-19-2015, 11:58 PM   #21
hardtimes
hardtimes's Avatar
Default Re: Oil Filter?
[QUOTE=Ed Pitts;1159388]
Originally Posted by hardtimes View Post
Hey Ed,
Hm, nice option , but looks to be 'below' block...how/what fastened to
I made a bracket that attaches to two of the oil pan bolts and the assembly then bolts to the bracket. Gets the filter down and out of the way. Ed
Hey Ed,
Good idea, thanks ! I've been trying to figure out an 'out of the way' location for my Kong full flow oil device on a B that I finishing up. I want to use the B fuel pump this time and your app might just give right solution.
hardtimes is offline   Reply With Quote
Old 09-20-2015, 09:37 AM   #22
daveymc29
daveymc29's Avatar
John La Voy did an article on his testing of the oil filters in the Times a while back. I do believe that the filters were cut open after use. It might be useful to look up that article. If you don't have the old magazines you couldcontact him and buy one, perhaps.
daveymc29 is offline   Reply With Quote
Old 09-20-2015, 10:37 AM   #23
katy
katy's Avatar
Has anyone cut open their used filters to see what, if anything, was trapped in the filter?
I did an oil and filter change on our son's well used '94 pathfinder one time that he had "forgotten" to get serviced for a long time. He had put on 27,000 kilometers (~17K miles) since it was serviced. I cut the filter open to see what the inards looked like and was surprised that it wasn't chock-a-block full of crap, just the usual dirty mess that one see's on a 5K mile filter's inards.
Old 09-20-2015, 11:20 AM   #24
hardtimes
hardtimes's Avatar
Hey katy,
Yeah, another yute's horror story of engine abuse..sounds all tooo familiar !
Regarding oil filter replacement, there was a time, I was informed that the filter could / should be replaced...every other oil change is perfectly ok. I used to do that when the filter was cheap, now not so much and they are no longer cheap. Of course, this would be dependent on condition of engine insides.
Old 09-20-2015, 11:28 AM   #25
CarlG
CarlG's Avatar
Cutting the filter open will reveal any metal, ie: Babbitt, aluminum, etc. Catch it before it's gone way too far.
Aircraft mechanics open them every time for that specific reason.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-20-2015, 02:56 PM   #26
40 Deluxe
I think that if you are finding Babbitt, aluminum. etc., the problem has already progressed into the 'gone too far' category! Pieces of Babbitt would indicate a bearing starting to flake, which means it already has to be redone; but looking into the filter may save a breakdown 100's of miles from home.
Old 09-20-2015, 05:29 PM   #27
CarlG
CarlG's Avatar
That's the part I was talking about!
Alaskan A's
Old 09-21-2015, 01:58 PM   #28
Tom Wesenberg
Tom Wesenberg's Avatar
Use a giant pipe cutter or tin snips to cut the filter open, so you don't introduce a lot of metal chips from using a hacksaw.
Old 09-21-2015, 04:13 PM   #29
CarlG
CarlG's Avatar
How about a can cutter something like this?
(works pretty much like a kitchen can opener.)
Alaskan A's
Old 09-21-2015, 04:55 PM   #30
Dave in MN
Dave in MN's Avatar
Originally Posted by 1955cj5 View Post
Does anyone use an oil filter, either full-flow or bypass?
I think I like the Snyder's style that replaces the timing side cover....just because it looks like a neat installation...
http://www.snydersantiqueauto.com/oil-filter-kit-2054
I think the side timing gear cover filter assembly will filter less than 15%-20% of the oil pumped.
The A-6705-F $169.95 / ea. (Snyder's) filters almost all of the oil passing through the pump.
I am in agreement with John LaVoy. IMO: I think the valve cover filter is the best available. (A-Ford-Able Full Flow Oil Filter)
Good Day!
Dave in MN is offline   Reply With Quote
Old 03-03-2019, 12:00 PM   #31
Cave
Cave's Avatar
Ed Pitts' post inspired me to do something similar - draw off the block do a bypass through the filter and then dump back into the sump - except I tapped the timing cover instead (easier to remove for the drilling and tapping).
I mounted mine higher because of the splash shields. You may wonder... I used SAE 30R7 hose with 1/2" steel springs wound around it to avoid crimping in the bends. Pressure shouldn't ever be a problem.
I'm getting a full crankcase oil change every 15 minutes at idle.
Cave
Cave Luther
Syracuse, NY
1931 Deluxe Coupe (Rose)
______________________________________
"... I'm pullin' for ya, we're all in this together." Red Green
Cave is offline   Reply With Quote
Old 03-03-2019, 01:01 PM   #32
1929
I was told to use this filter.
1929 is offline   Reply With Quote
Old 03-03-2019, 01:52 PM   #33
Railcarmover
If you run the full flow filter with the bypass lube line to the center main bearing you actually 'pressurize' the center main bearing to the extent the filter media provides a restriction to flow. This is part of the center main lube line,drill the cap and install a brass fitting...the rest can be done by drilling the oil pump shaft housing and tapping it.and connecting the two fittings with a steel tube..
Railcarmover is offline   Reply With Quote
Old 03-04-2019, 07:22 AM   #34
brokenspoke
brokenspoke is offline   Reply With Quote
