04-19-2015, 11:09 PM | #1 |
My '55 Ford Mainline Project
Newbeee here. Here is my '55 Ford Mainline project. It has a 5.4L DOHC Lincoln Navigator motor, 4R70W Trans, aluminum drive shaft and Ford 9". All the body work is done and the drivetrain is in the car. It also has a front disk conversion and rack and pinion. I just got done wiring the MSD module to control the engine and will be moving onto the trans computer next. I just have to figure out what I did with the throttle position sensor...... Then it's off to a fabricator to figure out how to mount to the column to the rack as the engine is in the way... I look forward to updating this thread as my project moves along......
04-20-2015, 06:18 AM | #2 |
Re: My '55 Ford Mainline Project
Welcome. That looks like it's going to be one nice ride. That ol' 55 should fly with that 5.4 set-up you have. Dan
Dan Kingman Az. 86409 |
04-20-2015, 09:54 AM | #3 |
Love you're car and the fact that you are using carburetors.
Confused why you need a throttle position sensor though. Sal |
04-20-2015, 10:09 AM | #4 |
Very nice car, love the dual carb setup
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford |
04-20-2015, 10:58 AM | #5 |
Thanks! The TPS is for the transmission controller.
'55 Ford Mainline-Work in Progress '14 Mustang GT, 6m, Recaros, Nav '12 Ford Edge Last edited by daustin; 04-20-2015 at 12:34 PM. |
04-20-2015, 11:52 AM | #6 |
'55 Ford Mainline-Work in Progress '14 Mustang GT, 6m, Recaros, Nav '12 Ford Edge |
04-20-2015, 08:26 PM | #7 |
Cool.
1956 Meteor Niagara Hardtop, 1 of 700 1969 Torino GT convertible 5.0 HO C4 1994 F150 XL short box 2006 Freestyle SEL |
04-21-2015, 09:41 PM | #8 |
Very nice start, and looks really good.
If brains were wire, some couldn't short circuit a firefly |
10-04-2015, 07:59 PM | #9 |
Dude you teased us, what's going on
10-05-2015, 01:33 PM | #10 |
as for your air cleaner maybe one that drops over the carbs sort of recessed like they used on the hemi's
10-05-2015, 02:10 PM | #11 |
That is one SWEET power plant!!!
Rowen
Alive n kickin n mostly kickin! |
10-05-2015, 04:04 PM | #12 |
just wondering how he will fire the thing?
10-05-2015, 06:08 PM | #13 |
That's a awesome project, if you have to scoop it try a 55 Tbird style or the old super duty trucks.
10-05-2015, 08:42 PM | #14 | |
10-06-2015, 10:52 AM | #15 |
I'm pretty sure there are cog belt driven distributors out there for racing that could be used to handle the spark.
Sal |
11-03-2015, 02:21 PM | #16 |
greetings to all, just joined the forum. Working on a 1956 ford wagon, and saw where you installed a 4r70w in your 55. I plan to install a 4r70w behind a rebuilt 312 I have in the wagon and I would like to know if you had to modify the trans tunnel, and what trans controller unit you used. I will be starting a thread on my build, looking forward to the group.
11-05-2015, 09:23 AM | #17 |
Damn, that is cool. Its gonna be a badass ride.
11-17-2015, 05:22 PM | #18 | |
Now , where is daustin , and the latest on the cool '55 Mainline ? |
11-24-2015, 08:16 AM | #19 |
For those asking about the ignition and distributor the MSD box he referred to in the OP uses the original cranks sensor to control the coils. There is no distributor, just the original 5.4 coils.
