02-12-2023, 06:11 PM | #1 |
Anyone know what this is for?
I found this box under my seat mixed with the tools. I never saw anything like this or needed to use one before. Is this something I will need? Thanks
Stickshift 1915 Model T touring 1931 Ford Model AA Flatbed |
02-12-2023, 06:33 PM | #2 |
Re: Anyone know what this is for?
It’s a king pin set, jack up each front wheel, grab top- bottom and wiggle, look for movement where end of axle connects to spindle, when it is good there will be no perceptible movement except slight wheel bearing play
The parts places sell a kit of all the small pieces to make up for what is missing. |
02-12-2023, 06:35 PM | #3 |
When the front end gets loose you'll need that set of king pins.
02-12-2023, 06:44 PM | #4 |
Eventually yours will wear out and need replacement - or yours are already worn out and the last owner got the parts but never installed them. They are the king pins that hold the spindle to the front axle. It easy to check if yours are worn by jacking up the front wheel.
https://www.youtube.com/watch?v=trQaA7dKSfU |
02-12-2023, 07:14 PM | #5 |
More...the old and the new....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
02-12-2023, 08:54 PM | #6 |
02-12-2023, 09:18 PM | #7 |
It is certainly not something you need to carry around under your seat unless you are planning to do a roadside seminar on changing out king pins, haha.
The Master Cylinder Enjoying life at the beach in SoCal... |
02-13-2023, 08:33 AM | #8 |
Spray with a thick oil film and store in your parts inventory.
02-20-2023, 06:02 AM | #9 | |
Stubs. |
02-20-2023, 05:42 PM | #10 |
I think I'm o.k. on the wheel bearing. I snugged it to the next slot on the castle nut and the top-to-bottom play was gone. I usually snug these up to seat the bearing, then back off and let the weight of the wrench determine where to place the cotter pin. I learned the hard way about overtightening wheel bearings. School of hard-knocks. One question though, I only saw one through hole on the spindle for the cotter pin. Maybe the grease was in the way, but I thought there might be two holes for more options.
02-21-2023, 03:58 AM | #11 |
Usually only one hole, best to my knowledge.
02-21-2023, 09:30 AM | #12 |
And King-pin change out CAN be a bear. Best done with the front axle removed entirely from the car, stripped down to the wishbone and done with a press.
As a young fart I did it by the "hammer loose" method while on the car, which I don't recommend. A porta-power might make this work if you can arrange a proper "strongback" to work against. There have been reports of "defective" king pins among the modern repops. Either made incorrectly (i.e. the wedge bolt slot which hold them in place) or bad metallurgy. Yours don't appear to be this. Yours would be a "saver" for me. "New Old Stock." (NOS) And you'll need the appropriate "king pin reamer" for sizing the bearings/sleeves. These can be bought new, or a much better buy found on Ebay. I think I paid $28 for mine with shipping - but I was patient. Joe K
Shudda kept the horse. Last edited by Joe K; 02-21-2023 at 09:43 AM. |
02-21-2023, 10:00 AM | #13 |
Check this slide:
Bob Bidonde |
02-21-2023, 01:45 PM | #14 |
There’s really nothing hard about changing King Pin Bushings.
Here’s a step by step video I made when I did mine. https://youtube.com/playlist?list=PL...gvqn60A_JPvFda
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
02-21-2023, 11:32 PM | #15 |
Just wondering, are "AA" truck king pins larger in diameter so they won't fit a car axle?
02-22-2023, 12:28 AM | #16 |
The label on the side of the box states 30 and 31 ford truck, so I think there might be a difference.
