02-23-2022, 04:30 PM | #1 |
1930-31 Roadster seat question
What parts do I need to put together a roadster seat?
Seat base Seat back base Seat and back springs Are there adjusters on a roadster seat? Best place to find used or buy new pieces rather original ?? Thanks |
02-23-2022, 07:02 PM | #2 |
Re: 1930-31 Roadster seat question
Hello, no adjustment on roadster seat just sit inside metal riser riveted to floor pan . Snyders makes seat springs ,usually the originals are rusted and wore out . I think the basic parts of the seat would be the back spring that is attached to a wood frame and the lower spring that sits in the riser as mentioned before. The below the lower riser is a angled floor pan where the side curtains are stored.
02-23-2022, 09:07 PM | #3 |
Thanks much !!!
02-23-2022, 10:13 PM | #4 |
There is what Ford called a seat adjuster. It is really a 2 piece "package shelf" mounted behind the backrest. There are 2 sets of screw holes for attaching the 2 pieces together allowing a slight change in the tilt of backrest. These 2 pieces are reproduced and available from the usual vendors. By the way, I sent you a private message the other day regarding the parts you were looking for. If you didn't see it, just click on Private Messages at the top of this page.
02-24-2022, 12:42 AM | #5 |
Picture of Ford Model A Seat posted by gdmn852 |
02-24-2022, 07:49 AM | #6 |
03-07-2022, 06:40 PM | #7 |
I used the short seat from a Dodge minivan and had it upholstered. Worked great and much more comfy than the original
03-16-2022, 10:46 AM | #8 |
I replaced the original springs with 3" seat foam, very comfortable
