10-02-2018, 07:35 PM | #1 |
Engine Ticking sound
Hi guys. I have a 1928 tudor. I recently noticed a ticking sound from the right side of the engine that was not there before. Can anyone steer me in the right direction for diagnostic and possible fix?
10-02-2018, 07:40 PM | #2 |
Re: Engine Ticking sound
Does the ticking increase when you rev engine? First thing I would think of is a sticking or slow valve. Do you use MMO in your gas?
10-02-2018, 08:20 PM | #3 |
Put a new manifold gasket on. Easy job.
10-02-2018, 08:42 PM | #4 |
I had one with a loud ticking sound, put in the MMO and cranked it over with the key off them pulled it to TDC and put about a cup in the suspect cylinder and a week later filled the neighborhood with blue smoke, but ticking all go away. Worked for me and now I use the MMO in our ethanol gas, 4 oz. to a full tank. Been told tranny fluid will do the same. Since I buy MMO by the gallon I find I'm not all that worried about the cost. It is, after all, a ten to thirty thousand dollar toy, so why worry about the minor costs?
10-02-2018, 11:12 PM | #5 |
I haven't noticed a difference with the engine revved up yet. I'll check it out tomorrow. I have not added MMO to the gas, but I will try that also. Thanks.
10-03-2018, 12:29 AM | #6 |
10-03-2018, 01:21 AM | #7 |
Possible that the cam nut has come loose. Take the little side cover off and see if the cam is loose.
Tom Endy |
10-03-2018, 08:36 AM | #8 |
Does the ticking go away after the engine warms up?
10-03-2018, 12:00 PM | #9 |
If the block is worn in the tappet bores, it will tick. The cure? Oversize tappets.
10-03-2018, 02:03 PM | #10 |
Try to isolate the noise, lifters, exhaust/intake, timing cover. That'll help us.
10-24-2018, 08:55 AM | #11 |
Hello guys. Sorry I did not get back sooner to update you. I did as Jackson suggested and changed the intake manifold gasket and the ticking sound disappeared. I added a little MMS to the fuel as an added measureand everything seems fine.
10-24-2018, 09:07 AM | #12 |
10-24-2018, 12:03 PM | #13 |
Your ear just went to school.
10-25-2018, 01:26 AM | #14 | |
that other stuff doesn't sound very good... |
