10-24-2021, 01:27 PM | #1 |
Top loader 3 speed parts condition help
I’m currently converting my open drive 3 speed to closed drive. My thrust washers have some pretty serious scratches and grooves in them from years of use. Is this considered a wear item that should be replaced or do you just continue to run them as is? Placing and order for seals and bearings so figured I’d ask first. Thanks! Chris.
10-24-2021, 02:37 PM | #2 |
Re: Top loader 3 speed parts condition help
The thrust washers are replaceable the surface areas that are important are the front and rear surfaces in the trans.case where they are. There is a specific measurement between that distance. Get the VANPELT Book on how to rebuild a Transmission and the parts list.
10-24-2021, 02:50 PM | #3 |
Best order thrust washers along with your seals and bearings, IMHO.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 10-24-2021 at 02:57 PM. |
10-24-2021, 02:52 PM | #4 |
The thrust washers are available in a couple different thicknesses. You need to let us know what year transmission and gear set - there are differences. I only build transmissions with the later 39 - 48 gear sets. I set the overall main shaft gear pack to have a thrust clearance of about .003 to .004 max. I frequently have to "tune" the clearances via slight modifications to thrust washers and/or the back of 2nd gear - though I have a precision surface grinder to do this work (very few would have that).
Another super important check is the shape of the front bearing surface of the mainshaft. These are frequently worn - something you don't want. You need the mainshaft to be in as good of a shape as possible. Lastly, I have Charlie NY rebush my 2nd gears for a tight fitment. I want a slight drag on the mainshaft (spinning the 2nd gear by hand). Another thing to ponder are the 3 caged roller bearings (2 in cluster, 1 on mainshaft) - I have yet to find any repop ones that are worth a crap. The cages are not hardened and the bearings tend for fail after limited use. Try to use original Ford bearings - either good used or maybe you can locate NOS ones (is difficult). Cluster Shaft: Measure the main cluster shaft - it really should not have wear on it. If it does, you can sometimes turn it over and put the wear side on the bottom (this helps). It is difficult to find NOS or good used Ford shafts - but they are the only ones I've found worth using. All the repop shafts are about .001 undersize, are too soft, use inferior materials and should not be used. Okay - enough out of me! B&S Last edited by Bored&Stroked; 10-24-2021 at 07:22 PM. |
10-24-2021, 03:00 PM | #5 |
All the things I mention above are necessary to prevent this issue. I for one can't stand having my trans pop out of second on deceleration - drives me nuts! LOL Last edited by Bored&Stroked; 10-24-2021 at 07:24 PM. |
