06-07-2014, 07:54 PM | #1 |
Ignition question
I am in the process of troubleshooting my ignition system due to a running rich condition. After setting the point gap and timing I check for spark when opening the points. I do get a spark at the points but I also hear a spark in the area of the coil or terminal box. I don't find any loose connections. I do not have the coil high tension lead in place. Where would this spark be occurring? Thanks. Howie
06-07-2014, 08:09 PM | #2 |
Re: Ignition question
It's probably jumping from the secondary to one of the primary terminal,
you should have the coil wire about 1/4" from the head. Bob |
06-07-2014, 11:04 PM | #3 |
Voltage has to go some where so it is finding ground through a crack or dirt on the coil. Bad for the coil.
06-07-2014, 09:59 PM | #4 |
