Old 03-22-2016, 12:49 AM   #1
tenniesgrandpa
Default 8BA comming togeather
About ready for assembly. 3 3/4, .060 over, .020/.020 crank. Four ring pistons using three rings. 95% oil filter mod done. Sent my cam in to Tony today for L-100 grind. All new stainless bolts washers for timing cover, pan, water pumps, intake. Grade 8 ss washers for heads. All stainless bolts I get locally for about $2 a pound, grade 8 are $3. Next will be heads,distributor, than intake and carbs. When all is done think the plan is a trike
with t-5 and 9". unless I find a Chevy to put it in.
tenniesgrandpa is offline   Reply With Quote
